Fosgate 1001bd
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=64052
Printed Date: April 18, 2026 at 8:29 AM
Topic: Fosgate 1001bd
Posted By: dragon51
Subject: Fosgate 1001bd
Date Posted: October 08, 2005 at 5:20 PM
Sice the subject of Fosgate has come up is that amp worth keeping or should I dump it off I also have 2 He2 12's that I was going to use in my own install to match up with my Boston Acoustic that I have for my mids. Ok here is what I plan on running Eclipse deck, Eclipse 4ch amp 50x4 PA5532 for my mids Boston Acoustic. I was also looking at the Eclipse 21010 eq then running the above sub amp combo but with only 1 of the subs in a ported box that I was going to fiberglass in to the spare tire well. I am after clean sound from my high end an good bass to round out my sound. And the ride is a Honda CRV So with the Fosgate line goning down is that sub amp combo better off being replaced?
Posted By: dragon51
Date Posted: October 08, 2005 at 5:23 PM
BTW I was going to run the sub ported at 35hz in the air space the manual call's for.
Posted By: chode69
Date Posted: October 08, 2005 at 6:08 PM
how is the fosgate line going down?
------------- -2x T112D2 ported box
-T1001bd amp
-T162C (front)
-T152C (rear)
-Pioneer Premier Deh-P360 Mosfet 50Wx4 head unit
-Pioneer CDX-P650 c.d changer
Posted By: dragon51
Date Posted: October 08, 2005 at 6:27 PM
After reading the post on fosgate opinions they did not fare so well by alot of people my self I have not had much problem with them but I am not after loud as much as quality. I want it to sound as close to my house set up in a bad inviroment but I can still get some what close and that is what I am after granted I have not spent near the money that I did on my home set up but I no longer 18 and just want to blow my ears out I am after the best sound I can get and I have no problem with dumping gear that I have collected over the years.
Posted By: chode69
Date Posted: October 08, 2005 at 10:20 PM
Question have you heard any systems powered by Rockford amps or complete rockford systems at all...they kick ass. You cant knock on something unless youve had experience with it. The reason people say that Rockford sucks is because they heard or have the "top of the line" equipment that cost THOUSANDS of dollars and comparing to a less costly system and anything that ins`t up to par with their system is shhh....i hate it. I can say how much i support Rockford due to many reasons ive owned other systems, installed, heard, dealt with and experienced many systems and what i got now which is Rockford and its because it was the best of what ive heard (with out going a few more thousand of my price range). And for around $3000 my system kills almost any system in my local area. Rockford amps are great. Dont ge me wrong I support many other brands im just a Rockford guy as you can tell.
-T1001bd amp
-T162C (front)
-T152C (rear)
Posted By: Bigsingh
Date Posted: October 09, 2005 at 3:15 PM
ok rockford stuff has gone a tad out of shape but i must admit their setups do kick ass, i still havent heard a sub for £120 that kicks like the p2 does, very bold and punchy bass. the he2's do suk tho, no offence, if u can get sum hx2's or any p2's or p3's, but keep the amp. although dd 1000 are kick ass subs.
------------- 6* Rockford T2's
6* POWER AMPs
BLACK CORRADO
BAANNGGIINN
Posted By: chode69
Date Posted: October 09, 2005 at 3:31 PM
I have some HE2s that I used to bump in my truck I took them out because I went up to T1s...but anyway HE2s do not suck. I had them hooked up to a T10001bd and they sounded great. They took some abuse too. With that amp get some Power T1s forget the punch models. The T1s have a cleaner sound than the HX2s as well. The Power HX2s might put out a little more SPL though. ------------- -2x T112D2 ported box
-T1001bd amp
-T162C (front)
-T152C (rear)
Posted By: melontop
Date Posted: October 09, 2005 at 8:22 PM
i have a t5002 i use to use on a set of p3's. i'm moving it to my mid and highs. on the box it said 500 watts rms, but the birthsheet says 990 watts rms  .almost underrated by half  . the t3002 are underrated even crazier thn that. both a good buy for the money. anyway i never had a problem with it. it pushes the p3's nicely. i,d keep that 10001bd and get a pair of t1's. i can't wait to get my t2's. i,m running them off of a t15002 birthsheet says2246 watts rms  . ------------- in process of putting rockford t2 12's in my 97 chrysler cirrus
Posted By: dragon51
Date Posted: October 10, 2005 at 7:15 AM
Cool thanks for the advise, I knew that there stuff was really good at one point like when I was still in High school over 10 years ago now. I will see about getting the T1 to replace my He2
Posted By: Bigsingh
Date Posted: October 10, 2005 at 8:33 AM
the He's dont suk, they cant hold a low note to safe their lifes. and a punch hx2 will offer alot more spl not just a bit more. but the t1 is a great choice of woofer, if you wanna full blow it why not just get a t2 great sound and mega output
6* POWER AMPs
BLACK CORRADO
BAANNGGIINN
Posted By: Bigsingh
sorry i mean power hx2
6* POWER AMPs
BLACK CORRADO
BAANNGGIINN
Posted By: chode69
Date Posted: October 10, 2005 at 11:27 AM
bigsingn what amps do you have powering the T2s? What size and ohm load are your T2s? (i looked at your signature)
-T1001bd amp
-T162C (front)
-T152C (rear)
Posted By: dragon51
Date Posted: October 10, 2005 at 8:06 PM
Ooops I'm sorry I just looked at them it is the Hx2 that I do have my bad
Posted By: melontop
Date Posted: October 10, 2005 at 9:26 PM
i'm with chode69 can we get a little more info. 6 t2's. how much you got pushing them? what kind of mids and highs do you have? theres no way you could hear factorys with 2 let along 6 t2's.
Posted By: chode69
Date Posted: October 11, 2005 at 5:57 AM
hey melontop you know you got me started on this forum now hahaha....
-T1001bd amp
-T162C (front)
-T152C (rear)
Posted By: Bigsingh
Date Posted: October 11, 2005 at 12:07 PM
yea sorry bout da late response, i've got 6 of the 10001bd running off 4 yellow tops with stinger top range alternator cant state which model. i've got the whole setup off 0 gauge wire. i know ur thinkin why not jus get the 30001bd, yea i jus wanted more amps on display and it was costing me the same
6* POWER AMPs
BLACK CORRADO
BAANNGGIINN
Posted By: Bigsingh
Date Posted: October 11, 2005 at 12:08 PM
and, the components i had runnin were the t162s but then i upgraded and went for a rainbow setup. i've got a punch range amp on the speakers.
6* POWER AMPs
BLACK CORRADO
BAANNGGIINN
Posted By: chode69
Date Posted: October 11, 2005 at 2:37 PM
Sounds like an awesoem set up!! you should post pics.
-T1001bd amp
-T162C (front)
-T152C (rear)
