Downfiring sub?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=64221
Printed Date: April 09, 2026 at 8:08 PM
Topic: Downfiring sub?
Posted By: ice8168
Subject: Downfiring sub?
Date Posted: October 12, 2005 at 12:19 AM
I have decided to down fire one of the two subs in a center consol box. The other will be facing foward.  My question is approx. how much space needs to be given between the sub cone and the floor?
I hope to begin the buils soon.
Posted By: ss-installer
Date Posted: October 12, 2005 at 6:23 AM
there might actually be a formula for this. how much excursion does the sub have? id say keep the sub atleast 2 inches up.
Posted By: DYohn
Date Posted: October 12, 2005 at 8:25 AM
And read the "woofer sag" sticky at the top of the forum to decide if your sub is capable of being mounted down (or up) firing.
Posted By: ice8168
Date Posted: October 12, 2005 at 9:41 AM
The sub is capable of being downfired.  It calculates out to 2% sag, so I am good there. To SS, the Xmax is 16.48mm.  Almost all the posts that I have read have stated the a downfiring sub might be the way to go.  As far as how much space need to be left between the floor and the woffer I am still unsure.  I also dont know haw much space needs to be left around the sub.  T0 clearify the bottom ofthe consol will look something like this:
      /________I`````````````````````I____________I
With the sud being here ^
Or would it be better to put the whole consol on "feet"
Posted By: stevdart
Date Posted: October 12, 2005 at 10:14 AM
Feet is the way to go...it opens up maximum airspace 360 degrees with only the small footprint of the feet blocking waves.  Allow plenty of room for max cone excursion...that's about it.  The sound waves will be forced out into space.  In the case of using a port, however, the space at the end of the port opening would have to be bigger (allowance for the proper function of port tuning).
My concern with such a setup as you described is that the two woofers are firing in different directions, which could muddy the sound with waves that cancel each other out when they hit at closer to 180 degrees apart than 0 degrees apart.  Would be akin to sometimes experiencing reverse polarity.  With it setup like that, experiment with reversing the wires on one or the other subs to see if they hit more powerfully together and in time with the mid drivers.  Chances are, though, if they are hitting at 90 degrees apart, no manipulation of the polarity would fix things.
But for the sake of your design, it's certainly worth trying and finding out for yourself if it will do the job.  Speculation and second-guessing is the easy part...the real test is the actual building and testing.  Good luck.
Posted By: ice8168
Date Posted: October 12, 2005 at 12:03 PM
I guess I could design it to have both subs downfire, would that be a better alternative?
Posted By: stevdart
Date Posted: October 12, 2005 at 8:30 PM
A pic I made for another subject but similar to this (I like to bring out old pics)...
posted_image
...because I like illustrations.  But this is to show that these two woofers are firing at 90 degrees from each other.  Reversing the polarity of one of them still results in a 90 degree difference.
This is one up, one down:
posted_image
...again, old pic drawn to show the difference in airspace in the boxes, but it works for this subject.  One of these could be reverse-wired and they would both fire in the same direction simutaneously.
And, of course, two woofers facing the same way and wired the same will fire simutaneously in the same direction.  Just said to finish the thought process...
So, knowing these things, you know what obstacles you would face if you faced your woofers at 90 degrees apart.
Posted By: ice8168
Date Posted: October 13, 2005 at 12:02 AM
Thanks to everyone for the help so far.
I think I will just set both subs to downfire and leave about 2" from the floor.  Does this sound like a better situtation?
