Which amp has best power & sound quality.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=64373
Printed Date: March 27, 2026 at 6:35 PM
Topic: Which amp has best power & sound quality.
Posted By: notorious_lou
Subject: Which amp has best power & sound quality.
Date Posted: October 14, 2005 at 2:48 PM
Which amp is best for all around power and music quality. Mmats D3000.1 / Digital Designs - Z1 / Orion 2500D
Posted By: Blowntweeters
Date Posted: October 14, 2005 at 3:36 PM
what ohm load do you plan on running the amp @ 4ohms 2ohms or 1ohm ?
------------- 1974 ford pinto 4 15" punch Z power punch bd 1001 pioneer DEH-6700
Date Posted: October 14, 2005 at 5:42 PM
Posted By: haemphyst
Date Posted: October 14, 2005 at 6:34 PM
I don't understand WHY people ask about sound quality when they are planning to run an amp at one ohm. At that load, there IS NO MORE sound quality. Distortion is higher - often times beyond 5% at that kind of load, damping goes to shiite - there goes your vented enclosure control...
At 4 ohms, however, I'd probably say the MMats, though.
------------- It all reminds me of something that Molière once said to Guy de Maupassant at a café in Vienna: "That's nice. You should write it down."
Posted By: forbidden
Date Posted: October 14, 2005 at 8:30 PM
More important than anything, what sub or subs are you using, what type of box, what is the vehicle? What are you doing for wire upgradeds? The lower you go in impedence, the more you sacrifice the amps ability to control the motion of the driver.
------------- Top Secret, I can tell you but then my wife will kill me.
