Ford Premium Sound
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=64486
Printed Date: May 16, 2026 at 10:16 AM
Topic: Ford Premium Sound
Posted By: Memphisman
Subject: Ford Premium Sound
Date Posted: October 16, 2005 at 3:49 PM
I have a customer who has a 1987 Ford LTD with the Ford Premium Sound System in it. He tried installing a Pioneer DEH-17 CD Player and only the rear speakers play (used a harness and everything seems to be wired correct). All the speakers work when using the factory unit, so I figured that the fronts run off an amp but I can't figure out what combination of wire(s) are used to turn it on. Any suggestions?
Posted By: gus1
Date Posted: October 16, 2005 at 10:42 PM
The amp lives in the trunk, passenger's side of rear deck.   What plugs are in the dash? The usual 8pin grey and 8pin black flat style plugs? I usually pull all 4 speakers to the back and bypass the amp on those cars.
Gus
Date Posted: October 17, 2005 at 10:47 AM
There are 3 gray plugs. One is an 8 pin plug for the speaker wires and the other 2 are 4 pin square plugs.
