box for an 18'' and two 8'' Ma Audio subs?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=64574
Printed Date: May 16, 2026 at 5:19 AM
Topic: box for an 18'' and two 8'' Ma Audio subs?
Posted By: 18ma audio
Subject: box for an 18'' and two 8'' Ma Audio subs?
Date Posted: October 17, 2005 at 11:37 PM
I have a 18in Ma audio subwoofer and two 8in Ma Audio subs.................................
What kind of box should i build for them i have room for a 29 cubic feet box what should i build or have built?????
please give me your oponion   thanx
Posted By: auex
Date Posted: October 17, 2005 at 11:41 PM
Ditch the 8's or use a seperate amplifier for them, with a xover set higher then the 18. You should go with the 18 for bass. Not good to mix different size subs, never mix different size subs off of the same amp without a crossover for both sizes and never ever share airspace.
As for box, personally I like sealed.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Date Posted: October 17, 2005 at 11:44 PM
i have seperate amp for the 8in subs i just got them for the higher bass. so your saying i need two crossovers??? what should i look for????
Posted By: auex
Date Posted: October 17, 2005 at 11:49 PM
If you have a seperate amp then you are set. If you are using 1 amp then you need seperate xovers.
Posted By: KarTuneMan
Date Posted: October 18, 2005 at 2:12 AM
The 8's need to be used for mid-bass....not sub-bass.....!
Posted By: eklipz17
Date Posted: October 18, 2005 at 2:27 AM
didn't dwarren already give you advice in your other thread?
