1999 Camry, amp bypass?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=64667
Printed Date: May 15, 2026 at 4:26 AM
Topic: 1999 Camry, amp bypass?
Posted By: ziggyb222
Subject: 1999 Camry, amp bypass?
Date Posted: October 19, 2005 at 3:48 PM
I am installing an aftermarket head unit in a 1999 Toyota Camry with the six speaker set up. Is there a special wire harness to bypass the amp to install the Pioneer.  Or do I just use what is listed on the Metra site, looks like the standard Toyota plug???
Posted By: outtaluck72
Date Posted: October 19, 2005 at 4:01 PM
most amplified toyotas have an amp bypass right inside the radio opening. if you look inside the radio opening toward the passenger side you will see 2 white wire harnesses plugged into their mating connector. unplug them and then you will have the regular Toyota harness Metra part # 70-1761.
Date Posted: October 19, 2005 at 4:34 PM
Hey thanks alot for the information. I am doing this job on the road so I didnt want any surprises...thanks again
Date Posted: October 30, 2005 at 10:36 AM
On this 99 camry.. I did not find the two plugs in the radio opening. So should I use the harness with only two plugs from Metra instead of the four plugs.. and also would the turn on lead have to be hooked up. I tried the two plug harness.. still with no sound...Any ideas??? Thanks
Posted By: geepherder
Date Posted: October 30, 2005 at 7:22 PM
Did you try to power the turn on lead?
Date Posted: October 30, 2005 at 8:41 PM
No I did not try the turn on lead.....
Date Posted: October 31, 2005 at 5:35 AM
Do that and you'll be good to go.  There should be blue jumper in the Metra harness.
Date Posted: November 10, 2005 at 7:29 AM
Thanks for all the help. Wired the turn on lead..still nothing.. found rear speaker in the trunk to have a broken terminal the owner tried to fix with super glue...soldered it back in place and was good to go...thanks again
