audio setup
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=64928
Printed Date: May 16, 2026 at 3:45 AM
Topic: audio setup
Posted By: fizzy15
Subject: audio setup
Date Posted: October 24, 2005 at 1:12 PM
Dear all,
I'm planning to setup my audio according to this
posted_image
please comment on the setup and security on my electricity system of the car
posted_image posted_image posted_image posted_image posted_image
Posted By: dwarren
Date Posted: October 24, 2005 at 2:24 PM
Well there is an arm sticking out of your battery, and I can't decipher any of those products except maybe that woofer is a fosgate.
What are your goals from this system?
Posted By: arrow12
Date Posted: October 24, 2005 at 3:28 PM
Profile probably isn't the best amp to go with.  If your on a real budget, then go ahead.  The Kappa coaxials are good.  The woofer is alright for entry level.  I can't tell what the headunit or the blue coaxials are.
That's my opinion. Take it, leave it, or correct me.
Posted By: forbidden
Date Posted: October 24, 2005 at 3:48 PM
Power wiring is waaaaaay too small. A 4 gauge line at minimum from the battery to the distro block and then 10 gauge line to either amp but preferably 8 gauge. Next if you have not bought a cd player yet, buy one that has 3 preouts on it to allow you to use the system properly and get rid of those nasty rca y cables. Yuck. I think that the arm sticking out of the battery is a nice touch and might start a new trend in the electronics industry.
Posted By: rottenbelly
Date Posted: October 24, 2005 at 3:49 PM
Might  want to go with heavier guage wire also. Dont forget the fuse.
rottenbellys 05 crew cab colorado.Pioneer dehp 880prs, kenwood excelon in all 4 doors. Bazooka 500 mono Jl 10w3 in coustom center console box.
Posted By: Blowntweeters
Date Posted: October 24, 2005 at 3:51 PM
your gonna want to use 4 and 8 gauge power wire. instead of 10 and 12 gauge
1974 ford pinto 4 15" punch Z power punch bd 1001 pioneer DEH-6700
Posted By: fizzy15
Date Posted: October 24, 2005 at 8:54 PM
posted_image posted_image posted_image posted_image thanks for all feedback.
i have redraw the pic. my goal is to add the 4 ch amp to my current audio system. im trying to find the best and cheapest solution posted_image posted_image
i take this approch as my HU has only one pre-out jack, and i just want to make a simple au connection without pre-amp or electronic crossover since the amplifier itself have buit in crossover. one more thing, do i need to install relay.
posted_image
please advice
posted_image
pioneer deh-p4750mp, MTX Audio speakers, apline amps, Rockford Fosgate Punch 10" sub
Posted By: dwarren
Date Posted: October 24, 2005 at 9:53 PM
Usually I do a relay after two points, so no, however if you do add anything else you should incorporate a relay.
My only other suggestion now, is to perhaps an upgrade your front speakers. They make the biggest difference in sound quality here. If you already have those co-axial speakers so be it, amp them. But if you are still in the market for speakers, invest in a nice compmonent set, don't worry about the rear fill so much.
Posted By: fizzy15
Date Posted: November 07, 2005 at 3:41 AM
well actualy I have with me all the things to setup my audio n I have install them all.
the sound is quite nice, but I have this problem.
-the amps are too hot, after long use, it will cut off and I have to wait till it cool.
-i dont know the best gain seting to aply on both amps.
could someone help me on these...posted_image posted_image posted_image
Posted By: arrow12
Date Posted: November 07, 2005 at 7:39 PM
Your overpowering your amp.  Use the search tool and search "gain."  You'll find a lot of good explanations for setting gains.
