common ground
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=65161
Printed Date: May 10, 2026 at 3:29 PM
Topic: common ground
Posted By: piggypigs3000
Subject: common ground
Date Posted: October 28, 2005 at 1:13 AM
Is it possible to hook up a new head unit to a common ground system?  Can you hook up all the negative speaker outputs to ground and there rest of the wires as you would normally?  I don't think that you can make this work but I thought I would see if I can get any help.          What about using a psi2, has anybody used one for a common ground.
Posted By: geepherder
Date Posted: October 28, 2005 at 7:58 AM
To put a new head unit into a vehicle with a common ground setup, you need to run new wires to all the speakers.
When I was installing professionally, a guy brought his boat to me, which had a common ground setup and he asked me about upgrading the speakers.  I told him I could do it, but he needed to upgrade the deck also.  He said he was trying to save money and only wanted to upgrade the speakers.  I told him it would play for a little while and quit.  He didn't care.  A couple weeks went by and he came back to upgrade his deck and speakers because it had quit like I told him it would.
