multi batteries
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=65256
Printed Date: April 03, 2026 at 7:51 PM
Topic: multi batteries
Posted By: Reeceddogg
Subject: multi batteries
Date Posted: October 29, 2005 at 6:53 PM
i done many searches on here and just want to make sure that when running multiple batteries and isolator isn't necessary, right?
Posted By: Alpine Guy
Date Posted: October 29, 2005 at 6:59 PM
right, as long as you have 2 of the exact same battery's off the exact same assembly line during the same time period.
Posted By: bajaclawz71
Date Posted: October 30, 2005 at 12:53 AM
Also if you are trying to use it as a backup battery than you will want to isolate them.
Posted By: KarTuneMan
Date Posted: October 30, 2005 at 1:13 AM
Just get an isolator......simple. Eliminate the potential for a problem.  Come-on.........
Posted By: Mad Scientists
Date Posted: October 30, 2005 at 7:56 PM
If you are using a second battery to run the system with the engine off, then you'd need an isolator. If you believe you need two batteries when the engine is running, then you'd need to try to match the batteries.. but I'd be curious why you'd need two with the engine running.
Jim
Date Posted: October 30, 2005 at 9:40 PM
I'm not worried about playing with the system off, i can just start the car. and since i'm buying the batteries at the same time i hope they are exactly the same
Date Posted: October 30, 2005 at 9:44 PM
sorry that's playing with the car off
Date Posted: November 01, 2005 at 6:07 PM
Why do you think you need multiple batteries? What are you hoping to accomplish?
Jim
Date Posted: November 01, 2005 at 8:27 PM
jus want to make sure i have plenty of power for my system and it doesn't look like just any single battery will do it
Date Posted: November 01, 2005 at 11:53 PM
Well the only time that you would be running your system off of the batteries is when the vehicle is off.  A second battery won't do anything for you.  You will need a higher output alternator if you run into too much current draw from your stereo.  Just as a side note a capacitor won't do much if anything either.
Date Posted: November 02, 2005 at 10:25 PM
[/QUOTE]
i figured that since after it discharges it'll take a while b4 it recharges therefore increasing the resistance to the amps, right?
