Rockford Fosgate p3001
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=65273
Printed Date: April 03, 2026 at 8:39 AM
Topic: Rockford Fosgate p3001
Posted By: adidas917
Subject: Rockford Fosgate p3001
Date Posted: October 30, 2005 at 12:58 AM
i dont know too much about what im about to ask....i have a RF p3001 class bd mono amp. I was wondering if i remove it from my subs if i could actually hook it up to 4 speakers, or would i be better off just buying a new amp for them. I know a mono can be made into two channels but i didnt know if you could break it down into 4.....possible? if so, how?
Posted By: menace2sobriety
Date Posted: October 30, 2005 at 1:18 AM
are you asking if you could use it for mid range speakes?  if so i would'nt its a mono amp not a stereo amp. buy  a 2 or 4 channel amp
Posted By: Blowntweeters
Date Posted: October 30, 2005 at 12:27 PM
i second this
1974 ford pinto 4 15" punch Z power punch bd 1001 pioneer DEH-6700
Posted By: dwarren
Date Posted: October 30, 2005 at 12:38 PM
If you look at the specs for this amp on the Fosgate site, it says this amp is a class a/b amp, not digital. However it is a mono amp with a frequency response of 20-20k Hz. So technically if you had four 4 ohm speakers you could present a 4 ohm load to the amp for 150 watts.
Now would I recommend you do this, NO. Get a four channel amp with the proper x-overs and do it right.
