amp question
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=65382
Printed Date: April 01, 2026 at 4:57 AM
Topic: amp question
Posted By: EM12986
Subject: amp question
Date Posted: October 31, 2005 at 5:33 PM
Is it possible to hook amp up to a battery charger. Will i now that is possible but can i have it play of sound  in some subs
Posted By: KarTuneMan
Date Posted: October 31, 2005 at 6:52 PM
No....not enough amperage....Look at a 2 amp trickle charger, then look at a big dog charger, 200amp quick boost, but not even 20/40 amps continuous.
Don't do it, youll toast your amp.
Posted By: youngone
Date Posted: October 31, 2005 at 7:15 PM
im looking at the same thing you are trying to do. im trying to run a amp in my house because i have no car(dam) long story. i have don some searching on the form and have found that ac/dc converters seem to do the trick and im thinking about geting a 40 amp cotinuas converter. dont no what you want to do with it. you could be bench testing amps or runing a sub or components in your house. people at shows use them so they dont have to keep there car runing to have there system playing for a long period of time.if you want some quality stuff take a look at this site https://www.astroncorp.com/linear.shtml if you are gust looking for something to run an amp like im thinking about doing. go to ebay and type in the search 12v power source. posted_image good luck tell me how everthing gose
Want to know some good equipment- JL,Adire Audio,Mcintosh,Brax,Helix,Eclipse,JBL,RE,Dimoand Audio,Zapco, pritty much anything DYhon,Forbidden recommend
On the12volt you give some info and you get in
Posted By: EM12986
Date Posted: October 31, 2005 at 7:19 PM
what would be the best way to bench test it
Posted By: menace2sobriety
Date Posted: October 31, 2005 at 7:38 PM
bench test it for what exactly?
Posted By: EM12986
Date Posted: October 31, 2005 at 7:41 PM
to see if it works
Date Posted: October 31, 2005 at 8:03 PM
add some cables to your amp, hook up the alligator clips from the charger, jump the turn on wire, give it some audio signal......MUSIC.
Low leval listening wiil work for a bit, but don't try and jam  for any extended periods....that chargers gonna get warm...
Posted By: youngone
Date Posted: October 31, 2005 at 9:09 PM
if you realy want to bench test you are going to have to run it at its full power so you are going to have to suply it with its full amont of amps but what you are implying that you gust want to see if it works. i was talking about finding power rating and amp drow. but for that a charger will work fine.
Posted By: EM12986
Date Posted: November 01, 2005 at 12:55 AM
yeah just need to see if it works w/sound
