Dayton Woofer Tester 2
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=65728
Printed Date: March 30, 2026 at 1:40 PM
Topic: Dayton Woofer Tester 2
Posted By: stevdart
Subject: Dayton Woofer Tester 2
Date Posted: November 06, 2005 at 7:17 PM
Does anybody own and use this tester?  Is it highly accurate, do you find differences from published specs, and is it worth the cost for occasional projects?
Posted By: dwarren
Date Posted: November 06, 2005 at 8:52 PM
Just buy it! Impulse buys are far better than long thought out, researched purchases.posted_image
You know you are pretty serious about this device, other wise you wouldn't have posted about it.
Posted By: menace2sobriety
Date Posted: November 07, 2005 at 12:38 AM
ill tell you what i will do for you!!! you buy it let me use it for a few months. and i will tell you if it was money wasted. how does that sound? pretty darn good deal huh!posted_image
Posted By: DYohn
Date Posted: November 07, 2005 at 8:18 AM
I've used their first version and it is highly accurate.  Every speaker will vary slightly from the published specs, but good quality brands not by enough to be significant, usually.  Is it worth the cost for occasional projects? probably not.  If you want to build highly accurate systems on a regular basis, then yes, maybe it is.
