Cd Changer in rav4
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=65855
Printed Date: May 16, 2026 at 5:40 PM
Topic: Cd Changer in rav4
Posted By: premb
Subject: Cd Changer in rav4
Date Posted: November 08, 2005 at 3:40 PM
Hi
I am installing a cd-changer (sony 10 disc CDX565MXRF) in 2005 rav-4 (L). So far I have done all the wiring – i.e ran the wires from sides of drivers seat to the trunk. Also fixed the connections to the antenna (got directions from sony’s website). Just to update, I had unistalled this cd changer from my previous Honda civic 02. while doing so I had taken pictures and tried to understand how i would then install it in the new rav4 05. I did all wiring and connection to relay box (antenna) from the unistall process.
the only 2 things remaining which I need some help with are
1.where in the trunk can I mount the changer as there has to be a black (lead) wire for earthing to be fixed to a metal in the trunk and I cannot figure a position for it
I did check my cargo area and the screws in there had a plastic like thing between the body and the screw - I understand that I need to remove (scrach off) this plastic material too OR is it even possible to stick this black wire on a metal part using some insulation tape of something
2. the other end of the electric wire which are in red and yellow – where and how do I fix them. I will connect the one end to the changer
Now, during my unstall process, the red and the yellow wires wire attached to 2 wires in a box (area with said fuse) below just under the steering wheel. I am not sure of the colors of those wires from civic but i can check from the pictures (one of them was orange). is there something similar I can do in rav4 instead of going to the battery and cigratte lighter?
any help / pictures will be of much help
Thx
Prem
Posted By: geepherder
Date Posted: November 08, 2005 at 7:53 PM
For the ground, just run the black wire to some metal (check the otherside to make sure it won't hit anything) and screw it down using a ring terminal- don't try to simply tape it in place.
For your constant (yellow) and accessory (red), use a multimeter (buy one if you don't have one) to test the wires under the steering column.  Constant should be white, accessory should be blue/red.
Posted By: premb
Date Posted: November 15, 2005 at 11:37 AM
Thanks geepherder
I got the black (lead ) wire knocked off the to-do list
but for the red and yellow wires -
1. From my previous un-install process i have learned that I could power-tap these from the wires located in the fusebox below the steering wheel in civic. however in Rav4 , its difficult to open this compartment under the steering wheel
2. without opening this compartment (fusebox), I was able to view inside (sneak) and there were a lot of wires.... is there a better can to create this power-tap.
anyone have some experience / pictures of the same
Thx
Prem
Date Posted: November 15, 2005 at 8:45 PM
If it's just for a changer, you could tap in behind the radio.  Blue / YELLOW should be constant (yellow).  Grey should be switched (red).
Posted By: premb
Date Posted: November 16, 2005 at 9:47 AM
Will i have to remove anything from the dash ? will my radio and cd player work when i am not plying the changers while doing this.
Do you have any links or picture which could illistrute this
Thanks for your particitance Geep
Date Posted: November 16, 2005 at 9:29 PM
You'd have to remove the radio to get to the wires behind it.  Your radio/cd player would still work.  You may check this out- I'm not sure if it's the same as yours: https://www.carstereohelp.com/stereoremovalToyRav4.htm
