Testing a used HU?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=66073
Printed Date: May 16, 2026 at 5:50 PM
Topic: Testing a used HU?
Posted By: jmjacks
Subject: Testing a used HU?
Date Posted: November 11, 2005 at 6:01 PM
Whats the easiest way to test a used cd player to see if it works without actually hooking it up in a car?
Posted By: chriswallace187
Date Posted: November 11, 2005 at 8:11 PM
You can power it up using a car battery. Take the constant and switched power wires and hook them to the positive terminal, ground wire to negative, and see if the unit turns on when you push power.
If you've got a speaker handy, you can hook the speaker wires up to it.
C Renner's Auto Electronix
