amp bypass
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=66093
Printed Date: April 01, 2026 at 10:42 PM
Topic: amp bypass
Posted By: nxtgenaud
Subject: amp bypass
Date Posted: November 12, 2005 at 1:13 AM
is there an amp i need to bypass in a 96 dodge avenger? unsure if it has bose or infinity sound system.
Posted By: HICKMANAE3
Date Posted: November 12, 2005 at 1:48 AM
From what i'll heard is that u can not play bose speakers in a car without a bose stero. Therefore you have to bypass the bose amp in order to play the speaker. I'm going off hear say with that
No security system can beat the tow truck :(
Posted By: 8dfoe regal
Date Posted: November 12, 2005 at 1:22 PM
yes you will have to run new wire from the radio , straight to the speakers.  The Factory wiring includes a pre amp, which will not allow an aftermarket radio to play.
Posted By: tcss
Date Posted: November 12, 2005 at 2:32 PM
Uhhh, don't think so. First, Chrysler doesn't use Bose, it should be Infiniy. If it is Infinity, they use a high level or speaker level input. So your aftermarket deck should wire right in.Get Metra's 70-1817 harness and make sure to hook up the blue/white lead from the deck to the blue lead on the harness.
There is no such thing as free installation!
