1998 S10, new deck
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=66488
Printed Date: April 09, 2026 at 8:26 PM
Topic: 1998 S10, new deck
Posted By: rones
Subject: 1998 S10, new deck
Date Posted: November 17, 2005 at 10:26 PM
I need to know how to hook up a new deck to a 98 s10. the factory stereo was ripped out along with the harness so i need the wiring diagram. The truck has the feature that the radio does not shut off until the door opens and i need help with this. Any help would be appreciated.
Posted By: menace2sobriety
Date Posted: November 18, 2005 at 12:56 AM
Stereo i could not find it for the s-10 this is for the gmc. it should br the same. but check it out.
Posted By: daze
Date Posted: November 18, 2005 at 3:52 PM
if the factory stereo turned off when the door was opened, then there probley is no 12v accessory behind there. So you would have to run your own. You could always us a meter to test the lines, battery to pop the speakers, or even take the speakers out and see what colors are there. Then pick up a factory harnes from a local auto shop or junkyard.
Thats my 2 cents.... take it for what its worth!
Nothing can replace experience
posted_image
Posted By: kirktcashalini
Date Posted: November 21, 2005 at 1:16 PM
There is a 12V accessory behind the unit. It goes off when you open the doors as well. I have a 99 blazer, and when i shut her off it still plays music even with the subs until i open the doors. I believe the particular color for 12V accessory is yellow. NOT blue... ;-)
