amp, high pitch whining noise
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=66993
Printed Date: April 11, 2026 at 5:53 AM
Topic: amp, high pitch whining noise
Posted By: cirrusly_fast
Subject: amp, high pitch whining noise
Date Posted: November 25, 2005 at 12:51 PM
Where to start?
Back in March I made my amp shoot flames, sent the amp to crossfire and got it fixed. When it came back, I hooked it up and noticed a high pitched whining noise. Kinda like a dail up modem. So right before I left for deployment I sent my amp back again.I have my amp back from crossfire again and installed it. There is still a whining noise coming from the amp. I noticed that if I turn the power to my stereo off, the whining stops, could it be the ground on my stereo, the accessory wire, or what?
So far I have tried a muting plug, ground loop isolator, and of course sending it back to the company. The amp still runs and I can hear awesome bass, but the whining sound from the amp can also be heard through the subs when they are hook up. So I worried about using the amp the way it is. I've spoken to many people about my ground from the spare battery to the amp and all say it should be fine. So what else could it be?
thanks for the help
Cuz I'm Kewl Like That.
System: 1-12" Orion H2, Crossfire VR2000D,Odyssey C2150 battery
Posted By: forbidden
Date Posted: November 25, 2005 at 12:57 PM
Amp shot flames.....any chance that the outputs of the cd player were shorted as well? Is this noise a set level, is it there only when the vehicle is running, is it up and down with engine rpm, what vehicle is this in, what have you done for grounding and size of wiring? Unplug the rca cables, is the noise still there?
Date Posted: November 25, 2005 at 1:06 PM
The outputs seem fine. The CD Player is fine. Noise is at a set level. It's whenever the CD Player is on, the vehicle doesn't have to be on. Not an alternator whine problem. It's in a 1997 Chrysler Cirrus. I have not upgraded the Big 3, however, from the stock battery in the front to the spare battery in the trunk the Pos cabel is 1/0 awg. The Neg cable on spare battery is 1/0awg and is grounded with a gold grounding terminal bolted to the chassis in the trunk.
I have unplugged the RCA's, Noise still there, I have used a muting plug on the RCA inputs of the amp, noise still there. I sent the amp back for this reason, noise still there. If I unplug the accesory power wire, noise gone, if i keep it plugged in, and turn the stereo off, noise stops.
Date Posted: November 25, 2005 at 1:11 PM
Unplug the speaker wiring and run new temporary wiring to the subs. Is the sound still there? Is the amp itself making noise or is it only coming from the speakers?
Date Posted: November 25, 2005 at 1:14 PM
the amp itself
Posted By: DYohn
Date Posted: November 25, 2005 at 2:21 PM
If the amplifier is making a high-pitched sound from the case with no input and no speakers connected to it, it is certainly defective.  Probably a fried power supply cap, a bad internal ground plane or a fried output stage feedback circuit.  Disconnect it.
Date Posted: November 25, 2005 at 2:36 PM
i was afraid of this, now when i send it back this will be the 3 time. it's getting pretty ridiculous, having to send the dang this back and pay $40 shipping everytime
Posted By: DYohn
Date Posted: November 25, 2005 at 2:44 PM
Get one of their customer service reps on the phone and carefully describe the problem, including that this will be 3 times back to them and they have failed to repair the problem.  Maybe they will kick in on the shipping.
Date Posted: November 28, 2005 at 1:37 PM
ok so the customer service rep, thinks it something in my car. what could it be? he says the last time they fixed it, they tested it for everything and would have caught the whining sound in the amp.
Date Posted: November 28, 2005 at 2:55 PM
well, i took it to a local audio shop and set it on their test bench, and sure enough there is still a whining noise. I'm right again. oh well now I'll call him and have him pay for shipping both ways.
Posted By: Teamrf
Date Posted: November 28, 2005 at 11:08 PM
Try using a different amp and see if the problem is still there..
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
Date Posted: November 29, 2005 at 6:12 PM
no, i put in on a test bench and it still did it, so i sent the amp off today. They offered to pay for shipping, but I'll be moving sonn and won't have an address for about a month, so I paid for it again. Since I paid for it and this is the 3rd time sending it back, the tech told me they were gonna send me a brand new one, which supposedly is better and has more reliability.
