’91 Grand Am stereo wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=67165
Printed Date: April 07, 2026 at 4:13 PM
Topic: ’91 Grand Am stereo wiring
Posted By: ang_ie
Subject: ’91 Grand Am stereo wiring
Date Posted: November 27, 2005 at 11:03 PM
  Okay- here's my problem... i have a '91 Grand Am. My factory wires were pulling out of the plugs. So I had to go buy a new harness- and the colors are different than my factory wires.  I re-wired all of the wires to the same wires that were cut from my original plug.... atleast i think. I also went to wiring diagram for my year/make/model. i matched everything up. Only thing- I don't have a pink factory wire. I have two dark grey wires...   Anyhow- after connecting everything- I plug the connecter plugs together for my cd player- and NOTHING. The power light does light up-but nothing else. No sound- nothing. But when I reconnect my factory tape player- It works just like before i re-wired. Which wasnt good either. The tape player only plays cassettes,therefore, no radio. Also- no lights come on the tape player- so i can not see what time it is. Also- before lights went out- i had no memory. my clock would go back to 12:00 after re-starting.  Do i need to re-wire some of these factory wires or what? I'm so confused. I have a cd player and an xm sattelite sitting in the box while im listening to old cassette tapes. I'm thinking I'm going to have to get deep into my car and re-wire the memory and I'm sure some others. Can anybody help me by letting me know if i'm on the right track- or what. I'm trying to avoid the money it cost for a PRO to put it in .
Posted By: geepherder
Date Posted: November 28, 2005 at 11:15 AM
Have a look around the fuse boxes for your car.  If your stereo keeps no memory, you probably have a blown fuse.
Posted By: ang_ie
Date Posted: November 28, 2005 at 2:40 PM
i havent tried that yet- but do think that would cause my new cd player to not even turn on. when i re inmstall the factory tape player- it comes on but only plays cassettes. it will not even go to radio.  any other suggestions?  did i explain my problem good enough in the original post?
Date Posted: November 28, 2005 at 2:58 PM
Yup, that's what it sounds like to me.  The factory unit probably only uses the constant lead for memory, and is actually powered through the switched lead.
Posted By: ang_ie
Date Posted: November 28, 2005 at 10:08 PM
Thank you so much for your knowledgeposted_image. i'm gonna check it in the morning. It totally makes sense to me after hearing you say the factory radio and the memory wire. I'll let you know if i get it.
Posted By: ang_ie
Date Posted: November 29, 2005 at 3:07 PM
ok....i checked out my fuse box- what am i looking for?  I'm assuming the battery and ignition, right? If so- I have 2 ign. fuses. One is a regular fuse and there is already a good one in it. The other is labeled IGN and there is no fuse in it. And it looks like its a 1 prong fuse. Is that correct? And then- theres the battery fuse. Again- it is empty with another 1 prong fuse needed. Are these the fuses I need to get my cd player going? If anyone is wondering why I'm asking about fuses and stereo installation.....Im a girl. Does that explain? lolposted_image   Thank you for all the help so far... I feel Im almost there.
Date Posted: November 29, 2005 at 7:50 PM
No, check all the fuses one at a time.
Posted By: ang_ie
Date Posted: December 01, 2005 at 2:32 PM
THANK YOU SO MUCH FOR YOUR HELP!!!!!!! I got it. I went out today and started messing around with the fuses. i checked them all- all were good. there was an empty space...RDO- i plugged it- and started the car----- I have a cd player and it turns on. If I only knew about the fusesposted_image . You are my hero geepherder!!!!!
Date Posted: December 01, 2005 at 5:46 PM
It's good to hear you got it working.  I don't know what rating fuse you used, but it may tell you in the owner's manual.  It's probably a 10 amp.
Posted By: ang_ie
Date Posted: December 02, 2005 at 11:44 AM
 I'm pretty sure i put a 10amp in. That or a 15. I'll keep my eye on it so it doesn't catch on fire.....that would suck. Another question... My boyfriends cd players screen is all messed up... Is there a way of fixing that? Or is it toast?You can't read what station its on. It shows 88:88..... It works well and everything, but if there's a way of fixing it- we'd like to fix it.  I figured you were the person to askposted_image  Thanks again for your time and wisdom.
Date Posted: December 02, 2005 at 6:12 PM
I bet it's got a bad microprocessor inside.  You could tell him to send it off to get fixed if it's still under warranty.  If it's not, I would recommend replacing it- now's a good time to upgrade.
Posted By: ang_ie
Date Posted: December 03, 2005 at 11:49 PM
O.K.   Thank You... He'll probaly just keep it since he has xm satellite and cd works.
