Amp has broken RCAs! howto hookup subs?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=67173
Printed Date: April 07, 2026 at 2:41 PM
Topic: Amp has broken RCAs! howto hookup subs?
Posted By: juiceylube86
Subject: Amp has broken RCAs! howto hookup subs?
Date Posted: November 28, 2005 at 4:37 AM
i have 2-channel 1600 watt Amp and 2 JL 10w3's. HU is a Sony CDX-F5710 w/ F,R, Sub RCA outputs. PROBLEM = broken RCA inputs on the Amp. Question = how do i hookup my subs if the HU doesn't have Speaker (High) level output for sub? is there some kind of adapter i can buy to bring low-level to High-level so i dont have to do surgery on the amp and resolder the RCA's? i know its probably my only option, but i've never soldered before, and also, i cant even get a decent visual of the solder points on the circuit board. what is the best/easiest solution?
juice86@gmail.com
Posted By: stevdart
Date Posted: November 28, 2005 at 7:20 AM
Have the amp professionally repaired. Any further advice to someone who "doesn't know how to solder" would be ill-advised. If all that is wrong is a broken connection, it should be a relatively inexpensive fix. But if there are other problems as well as that or instead of that, a technician will be able to find it out.
------------- Build the box so that it performs well in the worst case scenario and, in return, it will reward you at all times.
Date Posted: November 28, 2005 at 7:40 AM
thanks for the advise.....any recommendation on where to take it for repair?
Posted By: Alpine Guy
Date Posted: November 28, 2005 at 8:56 AM
Look up electronics repair in your phone book. A place than can do tv's and such will know what to do.
------------- 2003 Chevy Avalanche,Eclipse CD7000,Morel Elate 5,Adire Extremis,Alpine PDX-4.150, 15" TC-3000, 2 Alpine PDX-1.1000, 470Amp HO Alt.
