Audio relay?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=67219
Printed Date: April 07, 2026 at 4:01 AM
Topic: Audio relay?
Posted By: tomasito
Subject: Audio relay?
Date Posted: November 28, 2005 at 6:20 PM
I am upgrading the stereo system of a 1999 miata. I removed all of the bose system hardware. The bose amp was removed.
Question:
1. I am using a Pioneer DEH7700 for a head unit, what/where do I connect so that when I use the FM radio on the new HU the
antenna will automatically go up
2. Since I’m installing a new stereo system, is there still use for the audio relay?
3. Is the audio relay - controls the automatic up and down of the stock antenna?
posted_image
Tomasito
Posted By: suicidecustom
Date Posted: November 28, 2005 at 8:27 PM
in the amps harness there will be an ignition wire(12 volts when the key is on) and a power antenna wire. connect them and the antenna will go up when you turn the car on and go down when you turn it off
Date Posted: November 28, 2005 at 8:28 PM
sorry, if not it will be in the radios harness
Posted By: tomasito
Date Posted: November 28, 2005 at 8:52 PM
Is there a connection that the antenna will only go up, if I listen to the radio.
With the stock stereo (Bose) the antenna went up when I was listening to the radio, and it went down if I was playing the CD.
I am in the process of upgrading the stock stereo with a pioneer DEH-P7700MP
Tomasito
Posted By: geepherder
Date Posted: November 28, 2005 at 10:23 PM
Just use a wiring harness and it will make your job simpler.  Remember that many Mazda's use a negative trigger for the power antenna, so you may need to use a relay to convert the polarity.
