2002 gmc savana
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=67372
Printed Date: March 25, 2026 at 10:34 AM
Topic: 2002 gmc savana
Posted By: theweasel
Subject: 2002 gmc savana
Date Posted: November 30, 2005 at 11:53 PM
anyone heard of headlight issues after installing just an aftermarket deck?
Posted By: geepherder
Date Posted: December 01, 2005 at 4:55 PM
Be a little more specific and maybe someone can help.  Are your headlights dimming, or are they not working right?  Did you use a wiring harness for your vehicle to connect your new stereo?  If you did not, you may be using a wrong wire for power or ground (illumination or dimmer), which is causing you problems.  You need to rectify this before you cause any serious harm to your vehicle.
If your headlights are just dimming, consider upgrading to a relayed headlight harness to keep the voltage up higher.  A lot of times the factory wiring in cars will rob you of over 1 volt from the battery until it makes it to the headlights.
