how many 10" subs in 1.25 cf box?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=6750
Printed Date: May 16, 2026 at 7:54 PM
Topic: how many 10" subs in 1.25 cf box?
Posted By: tb116
Subject: how many 10" subs in 1.25 cf box?
Date Posted: December 15, 2002 at 10:22 PM
i have a 1.25 cf box and can put up to 4 10" subs in it, what would be the best choice,, just put two in or four.... i currently have 4 10" idq dual voice coil subs...... i know 1.25 cf is small but what would 2 vs 4 be in sound quality. or two & ported... sorry for the dumb question, just want it to sound the best. and get some decent spl....... or any recommendations on differnet subs?
Posted By: bberman1
Date Posted: December 16, 2002 at 10:57 AM
Each sub needs .25 - .50 cu.ft. Sealed and .75 - 1.00 cu.ft. Ported so either set up will work. If you run just two of them ported you will loose SQ as well as SPL compared to 4 sealed. However the 4 10’s can get some very good SQ if run correctly. If I were you I would run all 4 of them sealed.
