JBL amps, under rated?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=68689
Printed Date: May 10, 2026 at 7:19 PM
Topic: JBL amps, under rated?
Posted By: coppellstereo
Subject: JBL amps, under rated?
Date Posted: December 18, 2005 at 11:42 PM
Does anyone know if JBL's GTO series amp is under or over rated? We should make a list of all the amps we know that are over or under rated! Thanks for your help! -------------
Date Posted: December 18, 2005 at 11:44 PM
namely the GTO 601.1 -------------
Posted By: speedwayaudio1
Date Posted: December 19, 2005 at 12:49 AM
JBL is a first rate product.
------------- Big Dave
Date Posted: December 19, 2005 at 1:03 AM
i mean, is their power under rated. The amp is rated at 427 @ 4ohms. Was wondering if it could actually be more. I am looking for an amp for a 450w sub -------------
Posted By: sedate
Date Posted: December 19, 2005 at 3:20 AM
Um. That amp would be fine for a 450w sub.
It is probably rated very precisely...
Either way, you aren't going to hear an extra 50 watts or whatever you are looking for.
------------- "I'm finished!" - Daniel Plainview
Date Posted: December 19, 2005 at 4:15 AM
if anything they are under to right on the money. like I said 1st rate.
Date Posted: December 19, 2005 at 1:08 PM
could i use 2 channels of the the PX600.2 which are rated at 290w x 2 @ 4ohms. Is it ok to use a 2channel amp for a DVC? I've never done it -------------
Posted By: sedate
Date Posted: December 19, 2005 at 1:22 PM
Uhh. Bridge the channels, and wire the sub in series. You want the input single hitting the woofer to be summed, not stereo..
Date Posted: December 19, 2005 at 2:40 PM
if i bridge the PX600.2 the power will be 639w @ 4ohms. Should I do this or go for the GTO601.1 - 424w @ 4ohms? for 30 more bucks, might as well go for the PX, right?
