2001 mercedes benz ML 320 factory amp
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=68908
Printed Date: March 29, 2026 at 12:24 AM
Topic: 2001 mercedes benz ML 320 factory amp
Posted By: efini88
Subject: 2001 mercedes benz ML 320 factory amp
Date Posted: December 21, 2005 at 9:07 PM
I'm installing an extra amp to a 2001 mercedes benz ML 320 sport. I need to get to the factory amp so I can get the speaker wires to hook up to the hi-lo, but I can't find it. I was told it was in the trunk area. I took apart both side of the rear panels but there's nothing there except for a cd changer on the passenger side. Can the factory amp be located elsewhere? And also what are the colors to the speakers?, if avalable. Thanks, need info asap.
Posted By: geepherder
Date Posted: December 22, 2005 at 7:58 AM
I'm showing the left side of the trunk. If you can't find it, test the wires behind the deck.
------------- My ex once told me I have a perfect face for radio.
Posted By: jstruckman
Date Posted: December 22, 2005 at 11:18 AM
Those amps are usually located in the drivers footwell. Lift up the carpet and there is a storage compartment where the amp is locatated. You will have to unscrew a cover plate to access the amp.
Jazzy
Posted By: efini88
Date Posted: December 22, 2005 at 8:40 PM
thanks fellas :)
