Over RMS watt
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=69276
Printed Date: May 06, 2026 at 6:13 PM
Topic: Over RMS watt
Posted By: tomu2000
Subject: Over RMS watt
Date Posted: December 27, 2005 at 3:18 AM
The problem I have is that I am planning on running a 4 channel amp that puts out 4 x 50W RMS.  This much power for the rest of my speakers is fine but I have a set of Kicker KS35's for my front dash with a 20W RMS and a 40W max and I know I shouldn’t be hooking them up to this amp under normal conditions.  What I am wondering is if there is a way to drop some wattage out of the amp so I can safely run those speakers off of the amp or should I just run that pair of speakers off of the deck instead.  To be more specific with the amp it is a Lightning Audio B2. 300.4 900W max 4-channel.
Posted By: tomu2000
Date Posted: December 27, 2005 at 3:36 AM
There is actually one more question I had that I forgot to add.  I was just wonderin just how far away I should try to keep the 2 sets of RCA cables I will be bringing to the amp from my deck from the power that will be running to the amp.  Also, should I do the same with my speaker wire which is oxygen free double insulated 10 awg twisted pair speaker wire.
Posted By: geepherder
Date Posted: December 27, 2005 at 6:30 AM
Just power them off the deck- or upgrade the speakers.  Trying to drive those speakers off an amp will do little good if they survive, and they seem like they'd be matched to pretty much any head unit.
It's usually rare to have any problems running RCA's together with power wire.  I use the word usually because I have seen instances when this caused noise.  The rule of thumb is a minimum of 18 inches (many people just recommend running them on the other side of the car).  Keep the power and remote lead together, and the RCA's and speaker wire together.
Posted By: stevdart
Date Posted: December 27, 2005 at 8:16 AM
Keep in mind you'll have to have speakers that are capable of handling the full output of the amp in order to set the gains.  After that is done, you can just keep the volume down to reduce watts.
