amp/sub combo
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=69451
Printed Date: May 12, 2026 at 9:37 AM
Topic: amp/sub combo
Posted By: nuar
Subject: amp/sub combo
Date Posted: December 29, 2005 at 4:52 AM
This is my first time attempting this, so i'm VERY confused lol.
I saw the wiering options but i'm still puzzled.
Basically i'm gonna be buying a set of db124DVC Polk subs which have dual 4 Ohm coils. the subs are rated at 360 RMS for power.
I wanted to ask if those can be wired to the Audiobahn a8000t amplifier...
400 watts RMS x 1 at 4 ohms
800 watts RMS x 1 at 2 ohms
And if so, how? and will i have any problems with this setup overheating or anything?
Thank you guys!!
~Derek
Posted By: nuar
Date Posted: December 29, 2005 at 5:11 AM
One more question.
Would i be better off with the a8002t 2 channel amp instead?
200 watts RMS x 2 at 4 ohms
400 watts RMS x 2 at 2 ohms
800 watts RMS x 1 at 4 ohms
I'm guessing that would be the better choice? I'm using this image as reference...
According to the top image, the a8002t amp would be putting out 800 watts at 4 ohms, correct?
(sorry i'm really new to all this)
Posted By: dwarren
Date Posted: December 29, 2005 at 5:14 AM
Well here are the two options you will have with your dual 4 ohm subs...
OR
You will not be able to achieve the most common 2 ohm setup that most class D sub amps are optimnized for. However a nice two channel amp that is bridgeable will you suit you well. I might add that the audiobahn amp you have chosen will not produce the listed power, so steer very clear of that brand, please. -------------
Posted By: nuar
Date Posted: December 29, 2005 at 5:21 AM
Hmmm I didnt realize that the Audiobahn amps are overrated like that.
What kind of an amplifier would you suggest for the subs i listed?
Keep in mind i'm on a tight budget so i'd like to keep the costs down :)
Thank you for such a quick response!
Posted By: dwarren
Date Posted: December 29, 2005 at 5:25 AM
Well an alternative to the a-bahn amps that some people have good luck with are the hifonics amps, I personally have never had any experience with them, but what I have heard, they work well. JBL also has a good rep for producing a good over all amp at a very reasonable price. How about a budget? -------------
Posted By: nuar
Date Posted: December 29, 2005 at 5:29 AM
Well i would like to spend as little as possible on the amp without sacrificing reliability or quality.
What would be better fot this combo though?
A mono amp or a 2 channel amp
If i understand it right, the mono amp will put out the most power at 2 ohms, and the 2 channel amp will put out the most power bridged at 4 ohms, is that correct?
So what would be better for the dual 4 ohm coil subs?
Posted By: dwarren
Date Posted: December 29, 2005 at 5:54 AM
Well typically most mono class D amps are optimized to produce the most power at 2 ohms. Like this one and this one. So in your situation your best bet is to get a solid 2 channel amp, like this one or this one, however I cannot attest to the US acoustic ratings but my guess is that they are more honest than the a-bomb ratings. But you must not rule out a mono amp either, thye still will produce plenty of power at 4 ohms, and there may be a few out there that are cheaper and more powerful than a 2 channle amp, like this. Just remember I have nothing to gain from recommending you to a better amp, just a better piece of mind. -------------
Posted By: nuar
Date Posted: December 29, 2005 at 6:07 AM
Thank you very much for the speedy responses!
I'm a lot more confident with picking the amp now :)
Cant wait to get some bass in my car lol.
Have a happy new year man!
