Noise issue
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=69477
Printed Date: May 12, 2026 at 1:18 AM
Topic: Noise issue
Posted By: Steven Kephart
Subject: Noise issue
Date Posted: December 29, 2005 at 1:30 PM
We had a problem with some noise in a recent large system that we did, and I wanted to ask you guys a question. The install was in a newer Expedition and included a fully powered system, flip-out screen with navigation, etc. The amplifiers are mounted behind the back pannel and are very difficult to get to. The noise is a hissing sound in all the speakers, can be heard when the volume is all the way down, and seems to be louder in the rear speakers than the front. It is also independant of the vehicle being on or off. The gains on the amplifiers are set correctly (around half way up). When I unplug the RCA at the deck, the noise completely goes away. Doesn't that prove that the noise isn't being caused by the amplifiers or RCA's? After all, the amplifiers are still on and if the noise was being induced into the RCA's, then it would still be amplified when the RCA's are unplugged up front. I did the amplifier install, and want to prove that it isn't my install that is causing it, preferably without having to remove the back pannel to get to the amplifiers. If it helps, this was all used equipment when we installed it, including the RCA's. But it's all good equipment (Pioneer video/Nav, JL amps, Focal components)
Posted By: dwarren
Date Posted: December 29, 2005 at 1:49 PM
Have you tired stringing some RCA's through the car, not installed, to hear a difference? I still wouldn't rule out noise induced by the rca's as the magnetic field has lapsed when thay are unplugged therefore noise cannot be introduced any way. Do you have a common ground for your amps, or are they in seperate locations? -------------
Posted By: DYohn
Date Posted: December 29, 2005 at 2:00 PM
Pioneer head units are known for poor quality internal ground planes. Is the HU grounded separately to the chassis or did you use the OEM ground? ------------- Support the12volt.com
Posted By: geepherder
Date Posted: December 29, 2005 at 5:54 PM
Yeah, try grounding the outer shields of the RCA's at the deck and see if that does it, or try a completely different head unit. I bet it's a problem with the deck. (Pioneer garbage).
------------- My ex once told me I have a perfect face for radio.
Date Posted: December 30, 2005 at 3:17 AM
That was the next step, but I wanted to avoid that if possible as I would have to take off the back pannel. dwarren wrote:
They are both in the same location. DYohn] wrote:
/p>Pioneer head units are known for poor quality internal ground planes. Is the HU grounded separately to the chassis or did you use the OEM ground?
I didn't install the head unit, but I'm betting that the factory ground is being used. We have quite a few things we could still check to get rid of the noise. But as I was the one that installed the amps, I wanted to prove that it wasn't my work that was at fault.  geepherder wrote:
Oddly enough one of the installers suggested that, so I tried it and it didn't seem to help any. There is so much stuff connected to that thing, I'm not surprised there is a little noise coming through the system.
Posted By: DYohn
Date Posted: December 30, 2005 at 1:28 PM
Steven, anyone who would accuse you of doing faulty or half-assed work must not know you very well.  I suspect it's the HU or the HU ground. (Oh, and if you want to try the RCA shield-grounding trick, it must be grounded to the same ground plane used by the HU, not the amps, if they are different at all.) ------------- Support the12volt.com
Date Posted: December 30, 2005 at 7:31 PM
Yeah, and you can also try linking the amp ground to the head unit ground as well, but I do think it's the deck. Have you tried another unit? 'Attaboy, way to prove your install wasn't at fault. The shop I used to work at was occasionally accused of being a "hack shop", to which I replied, "I'm the only hack in this shop." ------------- My ex once told me I have a perfect face for radio.
