XJ6 amp location
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=70056
Printed Date: May 12, 2026 at 6:01 AM
Topic: XJ6 amp location
Posted By: Ren92
Subject: XJ6 amp location
Date Posted: January 04, 2006 at 5:28 PM
Does anyone know where the amp is on a 92 XJ6?
Posted By: geepherder
Date Posted: January 04, 2006 at 10:25 PM
Did you check behind the glove box?
Posted By: Ren92
Date Posted: January 05, 2006 at 9:07 AM
yeah kind of. I pulled the bottom off and there is a bunch of stuff under there but I don't see the amp.Know din cable seems to run down the side of the center console and to the rear.I have pulled the rear panels out but I don't see it there either.
Date Posted: January 05, 2006 at 2:31 PM
I think I've worked on a few older jags without amps- see if you can pop the speakers behind the deck.
