sub preamp outs?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=70216
Printed Date: March 30, 2026 at 9:39 AM
Topic: sub preamp outs?
Posted By: eaks
Subject: sub preamp outs?
Date Posted: January 06, 2006 at 10:58 PM
Hey guys.. i just completed my very first system 2 days ago.. i just ran one sub outta my one amp.. i am planning on expanding when i go to collage..
I have a cdx-m8805X deck with front and rear preamps and also sub preamps.. i did try it outta teh sub preamps and it didn't work (this is b4 we got the system fully working) *i may just take it apart tomarrow and try it*.. but i just wanna make sure that it should work.. since im just running my sub outta this i thought that would be awesome to do..
on the deck with the sub preamps they are not labeld poss/neg, they are both black.. so i guess ill just plug them in and if it dont work switch it around?
Ill try this out tomarrow and write back but i just wanna make sure that i have the correct idea here!!
Posted By: eaks
Date Posted: January 06, 2006 at 11:48 PM
Alright man.. thanks a lot.. i will test it out tomarrow morning b4 i go to hockey and poker.. i will post back later on and let u know how it goes..
ALSO: another question.. i noticed while driving at night that my ac/fan speed lights were out/dim, and half of the defrost/vent selection knob was out/dim.. the others were all fine tho.. Any ideas?
PS: 01 neon with just a candian tire motormaster matched battery.. and stock alternator!!
Posted By: eaks
Date Posted: January 07, 2006 at 10:02 AM
Alright.. its working now.. awesome..
now for my next question about the lights? anyone have an idea (^^^^^^ one post b4 this one)
Thanks a lot!
Posted By: DYohn
Date Posted: January 07, 2006 at 1:12 PM
Sounds like you blew a fuse.  I bet you didn't disconnect your battery before you installed the HU.  Check all fuses under the dash and in the engine compartment and replace any that are blown.
Posted By: eaks
Date Posted: January 07, 2006 at 8:47 PM
alright.. im gonna check thoes later tonite or tomarrow..
i know where the fuse panal is inside the car but am not possitive where the panal under the hood is! this is an 01 neon!!
Posted By: kirktcashalini
Date Posted: January 07, 2006 at 9:04 PM
Its probably because its a dodge, heh just kiddin. have fun taking panels off if it wasnt a fuse tho. good luck with everything, and learn to not use as many a's in replacement of other vowels posted_image. I normally unplug the battery before doing any electrical work. Even when just doing speakers or something, better safe then sorry I guess.
Posted By: eaks
Date Posted: January 07, 2006 at 10:44 PM
ok.. i checked the fuse panal inside the car and all fuses looked good.. i need to know where the fusebox under the hood is..
Posted By: eaks
Date Posted: January 08, 2006 at 9:41 AM
ok i may be a bit retarded..lol.. found the fuse box and am going to check them later today!
