XM antenna install in 2003 pontiac vibe
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=70291
Printed Date: March 31, 2026 at 10:22 AM
Topic: XM antenna install in 2003 pontiac vibe
Posted By: joker590
Subject: XM antenna install in 2003 pontiac vibe
Date Posted: January 07, 2006 at 7:59 PM
Can anyone help me with routing the antenna wire?  My car's FM antenna is at the back, and I'm not sure of the best way to route the wire.  Should I do it on the exterior or the interior, and how?
thanks for any help!
Posted By: sparkie
Date Posted: January 07, 2006 at 8:34 PM
It depends on what you are using for an antenna. If your antenna is designed to be roof mounted then you can mount it anywhere on your roof that room permits. If it doesn't have to be mounted on the exterior then mount it as far forward on the dash close to the windshield as you can. It may also help to have a small sheet of metal below it to act as a ground plain.
sparky
