30v dc out speaker terminal?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=70392
Printed Date: March 30, 2026 at 2:59 PM
Topic: 30v dc out speaker terminal?
Posted By: racerxx
Subject: 30v dc out speaker terminal?
Date Posted: January 09, 2006 at 11:37 AM
i have an audiobahn a18001dt that i ran across. it appears to be very unhappy though. it is putting out 30 volts dc from the speaker terminals with no input signal (the polarity is reversed too). anybody wanna tell me what to look for inside it to fix it? ive looked and found no visual indication that anything has popped. i was thinking maybe the caps were messed up?
Posted By: DYohn
Date Posted: January 09, 2006 at 11:54 AM
Sounds like it's passing rail voltage through, which usually means the output transisters are blown.  Trash.
Posted By: kirktcashalini
Date Posted: January 09, 2006 at 7:24 PM
I believe the last word in the last post was trash, and the subject manner was audiobahn. I would suggest trash it even if it works.posted_image cut it in half with a nice whiz disk and check it out from the inside, there may be something deep in there broken you wont be able to know unless you disect it.posted_image
