Remote cable
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=70479
Printed Date: March 31, 2026 at 11:55 PM
Topic: Remote cable
Posted By: digidemon
Subject: Remote cable
Date Posted: January 10, 2006 at 3:27 PM
 wireing in a amp in to my car i have got so far that all wires are connected apart from the remote how do i define  and where do i attach it at the back of the head unit
Posted By: rallysport
Date Posted: January 10, 2006 at 4:32 PM
what kind of headunit is it? the remote is typically blue with a white stripe (outputs 12v with radio on, 0 when off) . if its a factory unit youll need to use the accesory wire.
Posted By: kirktcashalini
Date Posted: January 10, 2006 at 5:22 PM
if you have a digital multi meter, turn the car on and see which wire gives 12 volts when the vehicle is on, then turn it off and if it doesnt give 12 volts youve found the accessory wire :) run 16 or 18 gauge to the amp and voilaposted_image
Date Posted: January 11, 2006 at 4:29 AM
ty very much guyz ill get that dun today  :)
