Amp turns off
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=7052
Printed Date: April 01, 2026 at 4:58 PM
Topic: Amp turns off
Posted By: Tinberland21
Subject: Amp turns off
Date Posted: December 23, 2002 at 11:38 AM
when i changed my amp to a different amp i turned up the volume and the amp shuts off then turns back on the shuts off again n turns back on...then when i lowered the volume it was fine but then when i turned the volume up the amp shuts off again n wont turn on...does that mean that i blew the amp??
Tin Le
Posted By: bberman1
Date Posted: December 23, 2002 at 11:56 AM
Sounds like you amp is going into protection mode. Might want to first check the wiring on your subs. What kind of subs and amp do you have?
Date Posted: December 23, 2002 at 1:12 PM
i have a kenwood amp wit 4ch 600 watts and 2 12 inch pioneer subs 400 watts each
Tin Le
Posted By: mack6820
Date Posted: December 28, 2002 at 8:08 AM
How big is your power wire and ground wire?
