Subwoofer Quit
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=71147
Printed Date: May 06, 2026 at 4:35 PM
Topic: Subwoofer Quit
Posted By: aschuete
Subject: Subwoofer Quit
Date Posted: January 20, 2006 at 1:03 AM
Yesterday, I installed an amplifier and connected it to the subwoofer, it played fine while I was in my driveway. About 5 minutes after I started driving away, the subwoofer paused, continued playing, repeated pause and play a few time, then it stopped playing. I came back, checked the fuses, grounds, and power connections, nothing was wrong, that i noticed. A friend suggested I try and exchange the amp, so i did. After replacing the amplifier the sub still will not make a sound. The subwoofer is a 12" infinity reference, the first amplifier was 550 watts max bridged, the second is 1000 watts max bridged both at 4 ohm. The subwoofer was just playing fine with no clipping. What could cause the subwoofer to stop playing?
Posted By: supradude
Date Posted: January 20, 2006 at 8:18 AM
Did you check and make sure the wires to the sub were connected? You can test the sub with a battery to see if it moves when you touch the wires.
'85 Toy
Posted By: aschuete
Date Posted: January 21, 2006 at 4:02 PM
That was it. A wire from the sub in the sub box popped off.
Posted By: forbidden
Date Posted: January 21, 2006 at 4:27 PM
So it was on strike and did not quit then, good to hear.
Date Posted: January 21, 2006 at 7:13 PM
Glad you found the problem.
'85 Toy
