2002 galant radio Problem!
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=71149
Printed Date: May 06, 2026 at 3:34 PM
Topic: 2002 galant radio Problem!
Posted By: hapache
Subject: 2002 galant radio Problem!
Date Posted: January 20, 2006 at 1:12 AM
Does anyone know where i can find corresponding colors of the stock radio for a 2002 galant, because i want to put an after market radio for a friend.    it was not on this website!    thank you in advance!
I'm on a mission to be as loud as i wanna be.
Posted By: geepherder
Date Posted: January 20, 2006 at 12:08 PM
Go to your stereo shop, and pick up a wiring harness for that car.  You'll wire the harness to the new radio- basically color to color, then plug it into the factory radio plug.
Posted By: nstaller36695
Date Posted: January 21, 2006 at 1:16 AM
also to add make sure u ground the radio separately that harness doesnt have a wire for that in the harness. theres a few 10 mm bolts behind the dash u can use with a ring terminal. that radio will ground when u mount it back down but u still want to make sure that it has enough ground before it goes in the dash thats also an iso mount radio so dont throw away the factory radio
the best part of a job is seeing the bumper get smaller over the horizon
Posted By: KarTuneMan
Date Posted: January 21, 2006 at 12:59 PM
