setting amplifier gains
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=71427
Printed Date: May 05, 2026 at 11:17 AM
Topic: setting amplifier gains
Posted By: Reeceddogg
Subject: setting amplifier gains
Date Posted: January 24, 2006 at 2:34 PM
I read most if not all the forum about setting the gains. i used this formula and tested with my dmm AC Volts = sqr(watts x ohms). I'm using two rockford 800.2 800x1 @ 4ohms. When i tested the output with no load bridged it resulted in 85-89 ACV on each amp. based on the formula i should only have sqr(800 x 4)= 56.57 volts. did i miss something cause this is way off and i only had the gains set at 1/3.
Date Posted: January 24, 2006 at 2:38 PM
The sub is the pioneer premier ts-w5000spl. also can anyone recommend a high spl box size for this sub. I would like it to be slot ported. if that helps
Posted By: DYohn
Date Posted: January 24, 2006 at 3:53 PM
Your math is correct.  Feed the amp a test tone within the subwoofer pass band at your max non-clipped input level.  800 watts into a 4-ohm load is accomplished using 56.6 volts AC.
Posted By: stevdart
Date Posted: January 24, 2006 at 4:01 PM
If you're going to use that method by itself you have to make some assumptions:  one is that the power output that the amp is rated for is what it truly is in your installation, and two is that the net load is exactly 4 ohms.  Either or both of these can be off.  For example, if the actual net load were 4.3 ohms, the result would go up to 58+ volts if you used 800 watts as power in the formula.  And so on.
Because of this, you should also use the listening test.  With either method you have to 1) use test tones in the frequency range of the subwoofer, and 2) have the volume level of the head unit at the highest output just under clipping level.  The test tones should be recorded at a reference 0 db level.  This means that the deck output must be tested and set before the amp gains are set.
When you hear the tone change to a clipped tone and then have turned the gain back down enough so that the tone is pure again, read the voltage output.  You will probably find that it is much closer to the specified power than what you found.  But if you again find a good, steady reading that is higher, then the power output may be more than specified.  You won't really know without doing a complete bench test, but you will know that the gains are set right.  The relative position of the gains (..."set at 1/3"..) has nothing to do with anything.
Posted By: DYohn
Date Posted: January 24, 2006 at 4:51 PM
What he said.  posted_image
Date Posted: January 24, 2006 at 9:53 PM
i did use a test tone that went from 100hz to 40hz and i got a read out of around 75-79 on each amp. so if i put that back in the formula from above that equals around 1200 watts. but that can't be correct, or is it.
Posted By: DYohn
Date Posted: January 24, 2006 at 10:31 PM
You are testing voltage with the woofer(s) disconnected, right?  Your readings could be correct, but it is probably clipping.  Reduce it down to 56.6 volts, then connect your woofers and perform the "by ear" fine tuning as Steve described.  Also, before you do anything, go back and ensure your HU is not clipping.  You can do this using the "by ear" test also, with the amplifier gain set to minimum.
Date Posted: January 25, 2006 at 1:19 PM
will do but what should i look for when i test the HU to see if it's clipping?
Date Posted: January 25, 2006 at 1:20 PM
Yes they are diconnected
Posted By: geepherder
Date Posted: January 25, 2006 at 6:05 PM
You're not looking, but rather listening.  When you begin to hear distortion ever so slightly, turn the volume back down until it goes away.  That will ensure you a max unclipped signal.
