ohmage vs. wattage?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=71660
Printed Date: March 14, 2026 at 12:02 AM
Topic: ohmage vs. wattage?
Posted By: deraynged
Subject: ohmage vs. wattage?
Date Posted: January 28, 2006 at 12:33 AM
looking for an amplifier to power three 10" eclipse aluminums rated at 400w/800w wired as a 2.6 ohm load. how much power would a 1200w @ 2ohm amp put out running a 2.67 ohm load? is there a calculator somewhere?
He Who Fights and Runs Away,
Gets Shot in the Back!!
Posted By: wrathchild281
Date Posted: January 28, 2006 at 12:53 AM
well it makes 1200 watts at 2 ohms and like 600 at 4 ohms then just figure out the middle of that and a then the middle of that again. so around 1000 watts roughly
Posted By: dwarren
Date Posted: January 28, 2006 at 12:55 AM
They will receive roughly 400 watts a piece, probably a little less, but there won't be an audible difference.
I assume the 800 watt rating is peak? Use the rms numbers on both subs and amps.
Posted By: stevdart
Date Posted: January 28, 2006 at 1:09 AM
No calculator for this that I know of.  It's just simple math, though, but write the results as you go through it.  You know what the rated output is at 2 ohms.  Now look at the rated output at 4 ohms.  Subtract the 4 ohm from the 2 ohm.  Divide that answer into two, and then add that result to the 4 ohm rating.  You now have an extrapolated 3 ohm output.
Compare the 3 ohm to the 2 ohm outputs.  Divide the difference between them by three to get  thirds.  Add one third to the 3 ohm output to get a 2.67 ohm result.
You can't extrapolate another "rated" output from only one given rating...but you can come up with a good guess as long as you have two ratings to work with.
heh heh....or do like wrathchild did and come up with the answer in your head.  posted_image
Date Posted: January 28, 2006 at 7:46 AM
was never real good at math but i got it figured out.
given:
600w @ 4ohms / 1200w @ 2ohms
couple notepad scribbles later:
900w @ 3ohms / 1000w @ 2.67ohms
thanx again.
