Hiss and little volume control
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=71749
Printed Date: March 12, 2026 at 10:12 PM
Topic: Hiss and little volume control
Posted By: italianlj
Subject: Hiss and little volume control
Date Posted: January 29, 2006 at 1:46 PM
I have just put a dvd/cd/radio in my 2000 toyota celica. It has a factory installed amp. I now have engine noise when the radio is playing and a loud hiss while the dvd is playing and the volume contol goes from loud to real loud. No real control. Can anyone help??
Larry
Posted By: DYohn
Date Posted: January 29, 2006 at 2:36 PM
Did you remember to remove or bypass the factory amp?
Posted By: geepherder
Date Posted: January 29, 2006 at 2:51 PM
The problem you've described is cause by running too strong a signal (speaker level) into the factory amp.  You can use an integration harness (check your other topic), or rewire (bypass) as suggested above.
