Orion H2 10" sub enclosure size?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=71949
Printed Date: April 03, 2026 at 8:39 AM
Topic: Orion H2 10" sub enclosure size?
Posted By: willdkartunes
Subject: Orion H2 10" sub enclosure size?
Date Posted: February 01, 2006 at 12:20 AM
I was wondering if 'hifisoundconnection' is a reliable source to order products from? I've heard about places with B stock equipment and was curious if this place is straight or not. Also, what cubic size for a sealed enclosure should be used with a single Orion H2 10inch dual 2ohm sub. I've seen many suggestions of .5 cu. ft., but that's pretty small for a sub with a magnet of this magnitude!
Posted By: samrock
Date Posted: February 01, 2006 at 12:39 AM
what year and model are your subs i have a lot of orion pdf i will email you the one for your speakers.  they have box specs wattage and sound q in the pdf.
thanks
samr rock
OF ALL THE THINGS I HAVE LOST I MISS MY MIND THE MOST!
Posted By: Ravendarat
Date Posted: February 01, 2006 at 1:14 AM
.5 is minimum air space AFTER DISPLACEMENT. and as you said that sub has a big ass magnet so you definatly have to take displacement into account. How much power are you running, that will help determine the size of the box you shoul;d use. Also what kinda vehicle is it going in and is it a sq set up or a SPL set up. Please dont say both, its either one or the other.
Date Posted: February 01, 2006 at 1:22 AM
It is for Spl purposes and it's going into a 1997 extended cab S10
Date Posted: February 01, 2006 at 1:34 AM
year-2005, model-H210.2, amplifier-Orion 1200D
Posted By: samrock
Date Posted: February 01, 2006 at 1:36 AM
if you have yahoo msg add me to you list i am kewlcat_68@yahoo.com i will send u the pdf for the hcca sub. my out going mail server is not working for somereason..
Posted By: samrock
Date Posted: February 01, 2006 at 1:39 AM
the pdf i have if for hcca d2 or d4.. i can get the other one tomorrow..  i will send to you when i get it
also you may want to dl winisd beta its a free program for doing box calculations
Posted By: samrock
Date Posted: February 01, 2006 at 5:24 PM
ok i have the pdf for the  2003 h2 sub. my tech support guy at orion said it is the same as the 2005 as they have not changed the driver. if you like i can email it to you or send it through yahoo.
sam
