2000 tahoe subs
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=72227
Printed Date: May 15, 2026 at 10:33 PM
Topic: 2000 tahoe subs
Posted By: chevy72ls3
Subject: 2000 tahoe subs
Date Posted: February 05, 2006 at 11:39 AM
hey i got a new pioneer 800w amp with 2 10" kenwood subs.  i am going to use the stock radio on my 2000 tahoe, its not the limited its the new body style , i have an adjustable line output converter for that.  i was wondering if i have to bypass the original amp?  i read that in another post on here and was wondering if thats true, also does it interfer with the onstar at all?
thanks
john
Posted By: geepherder
Date Posted: February 05, 2006 at 7:30 PM
No, you don't have to bypass the factory amp.  You can either connect RCA's directly to the headunit's outputs and run those to your amp, or you can use your line out after the factory amp.  If you use the loc, and you have a factory sub, you need to tap the sub wires, otherwise you can just use fronts or rears.  OnStar will still function the same.
Posted By: Ravendarat
Date Posted: February 06, 2006 at 3:09 AM
The factory head unit has not RCA outputs so the LOC is essensial here. The main thing is depending on whether you connect the LOC to the deck side or the speaker side of the amp will determine how you set the LOC. On the deck side you will find that it needs to be set higher where as on the speakers side you are gonna need to trim those levels down a little bit.
