will reversing polarity on sub damage it?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=72271
Printed Date: May 15, 2026 at 9:29 PM
Topic: will reversing polarity on sub damage it?
Posted By: parad0x
Subject: will reversing polarity on sub damage it?
Date Posted: February 06, 2006 at 4:48 AM
I just recieved a 8" Clarion 75w RMS subwoofer, I had JUST figured out today (Just found out about the AA battery trick pushing cone outwards for correct setting, after having played on it for about 10 hours total) that this subwoofer had been set up WRONG in the box.. IE, the + was put on the - of the sub, and the - was put on the + of the sub.. I tested it with a little AA battery, and the cone went INWARDS, meaning the polarity was messed.. fixed it and thought to myself wow I finally figured out WHY this system pounds soo poorly and very quietly.. I have a rockford fosgate 500.2 amp, with a jvc deck that supposidly puts out 4 volts.. I swapped the deck out, and rca too, and nothing has improved the poor bass in the car. Fixing the polarity fixed the quality of the bass, however.. It is still soo very quiet. Only time when the bass improves, is when I turn the speaker volume up to full to when the speakers start to distort on some bass notes and even then it is still not that very loud. I am trying to figure out, if running reverse polaritys might have buggered up this subwoofer? I do not know how long it has been reversed in polarity for, it was given to me all setup like that, so I do believe there is a chance this sub might have seen a couple hundred hours of play time in reverse polarity? Would having played the sub in the wrong polarity for this long possibly damage the driver/speaker? Or is there another problem in the setup somewhere?
Posted By: dahcmed
Date Posted: February 06, 2006 at 6:24 AM
I'm pretty much a newbie, but AFAIK, it's a practice to do reverse polarity when your sub is out of phase, there are HU's and Xovers that allow you to change/reverse polarity/phase without touching the wires. This is done when the sub seems to lag from the other speakers. As for the loudness, I'm just guessing, but I don't think you can expect too much from 75Wrms. How "not loud" are we talking about? Could be that or poor box design or wrong position. How is it setup (ported, sealed), box size, SVC/DVC, position in the trunk (facing cabin or rear), etc.? These details can help the gurus to give us the answer :).
Posted By: dahcmed
Date Posted: February 06, 2006 at 6:41 AM
Could also be faulty amplifier, gain set too low or xover set too high. How are these set in your system?
Posted By: david n germany
Date Posted: February 06, 2006 at 9:26 AM
No having it wired backwards will not damage it. As an example people doi it all the time in compound isobaric configurations. David
Posted By: parad0x
Date Posted: February 06, 2006 at 9:44 AM
I've already done all that, swapped the deck out with another deck of the same model. Swapped the amp out, same symptoms, I made sure the LPF were on the deck + amp, the gain is set almost at full and still the response is very weak its almost like the voltage coming out of the deck is minimal. It is in a bazooka tube, really primitive however the original stock sub that came with the tube was replaced with a better 8" Clarion subwoofer. The bass really should be better, I know for a fact that it's really too low. I mean it really barely bumps.
Date Posted: February 06, 2006 at 10:30 AM
Use the crossover on the deck OR the crossover on the amp do not use both. check your gains and also try a different sub.
Posted By: parad0x
Date Posted: February 06, 2006 at 11:01 AM
What would the result of using one crossver on HU, and one on amp? The thing is, with the head-unit, in the section where i adjust the sub-volume, there is a setting I have to select, either low, mid, high. there is no "full" selection, so i cannot bypass the crossover on this HU. So I take it, if I should make a change, it would be having to change the crossover on my amplifier to "full" ? It is currently at LPF
Posted By: haemphyst
Date Posted: February 06, 2006 at 12:06 PM
I think one other thing that most people are overlooking, is the fact that you may be, just might be asking too much from an 8 inch woofer... Perhaps you should possibly set lower sights for your 8 inch "sub", or get a bigger woofer. I appreciate the fact that you might not be willing to give up a LOT of space, but if this IS the case, then you will need to expect that you are going to be sacrificing output...
Ultimately, though, in answer to your ORIGINAL question, no, it is absolutely impossible to damage a driver simply by reversing the polarity on it...
------------- It all reminds me of something that Molière once said to Guy de Maupassant at a café in Vienna: "That's nice. You should write it down."
Posted By: wranglercory
Date Posted: February 08, 2006 at 10:43 AM
Check the OHM load on the sub see if the sub is just going bad , also with a 8" sub you wont get a lot of volume with just that .
Posted By: dirt_jumper54
Date Posted: February 08, 2006 at 10:20 PM
are u running the 8" 75w rms sub off the RF 500.2?If so u probalby blew the sub with in the first ten minutes and thats why its not loud.
Posted By: parad0x
Date Posted: February 09, 2006 at 4:00 AM
No it hasnt blown yet.. I havnt really taken apart the tube yet. And I Havnt had a time to check the ohms, but that is a good idea and will do just that with my multimeter next time. I doubt I would blow it though, if my friend is right (I dont know if he knows what he's talking about on this one), he says this is a 4 ohm SVC subwoofer.. and I have only had it attached to one of my channels.. so it is only putting out like 125 watts x 1 @ 4 ohms stereo, and that is if the ohms is 4.. I think there is a possibility, this subwoofer might be a SVC 8 ohms, or might have a damaged voice coil that reads much higher above 5.. As well, there is also a chance that this subwoofer is a DVC 4 ohm subwoofer.. in which case it might have been wired improperly by the person who originaly used it, and that it might have been wired in series with an 8 ohm load.. I will test it out when I get the chance to, and post my findings regarding the subwoofer.
Posted By: parad0x
Date Posted: February 09, 2006 at 10:27 PM
Thanks for the reply guys.. I figured it out.. It wasnt my expectations, the subwoofer really is way too quiete for what it should be putting out. I had just put a multimeter to the sub, and got a 13 OHM READING !!! LOL. I have never had a subwoofer before with such a messed up voice coil... and i've handled a lot of subwoofers. haha, my eyes almost poped out of my eye socket when I saw the reading.. 13 ohms, wow.. pretty high. I will be returning this subwoofer to my friend who gave it to me, and claimed to have been pounding it without a problem before he gave it to me. It has nothing to do with ME overloading it, I only ran one channel of my amplifier to the subwoofer, and the subwoofer was suppose to be rated at 4 ohms.. so that's about 125 watts RMS power, so it's not my fault... Actualyl, if anything, it was about 13 ohms when he gave it to me.. so I am really curious what kind fo power I was putting out? Anybody got any idea? If I can put out 250 watts RMS @ 2 ohms, and 125 watts RMS @ 4 ohms.. how much would i be putting out at a 13 ohm load?? My guess would be about 35 rms, what do you guys think?
