subwoofer and amp dont work after hook up
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=72336
Printed Date: May 16, 2026 at 1:16 AM
Topic: subwoofer and amp dont work after hook up
Posted By: aallbbeerrttttt
Subject: subwoofer and amp dont work after hook up
Date Posted: February 07, 2006 at 1:22 AM
i have a JVC headunit and i wanted to add a small subwoofer in the trunk of my 240sx just cause the rear speakesr are out and i want a little more bass
i got all the wiring part done since the previous owner had a system in it, the power and remote wire were already there, just a matter of hooking them up, i mounted a new ground wire and i hooked it all up to the amp
now the amp was also from the previous owner, and i have no clue what type it is or whatever, it was just there, he siad he was using it to power his speakers and never ran a sub, not sure if that matters, it also says 120w x2 on the cover
posted_image
posted_image
the sub has all of these connections
posted_image
posted_image
-power
-ground
-remote
-1 white RCA
-1 black RCA
-left speaker -
-left speaker +
-right speaker -
-right speaker +
and it also has these settings
-subwoofer level: 80, 120, "subwoofer off"
-mode: st, brg
so i was thinking today, if i just bought a cheap subwoofer and hooked it up, i'll have some bass right? so i got one from work, cheap 15 dollar POS that was on clearance, and tried to hook it up
i hooked up the power, ground, remote accordingly, and also the RCA cables, the power cable near the battery terminal didn't have a fuse in it, so i put in a 25amp fuse, the amplifier itself has a 30amp fuse in it, and it's still good
then i took regular speaker wire and i connected the subwoofer + to the "left speaker +" and the subwoofer - to the "left speaker -"
then i turned on the radio to see what was up, the amp turns on, and the subwoofer turns on about 1 second later, and i hear the subwoofer bump once, then the rest i hear is slight low volume thumps, it is always in the same pattern, bump..bump..bump..bump.. and it just keeps going when i play music, then if i turn off the radio, the subwoofer turns off and i hear a small thump before it goes off, also the subwoofer doesn't bump to the music at all
i got a couple questions
-did i hook up the subwoofer correctly? i'm only going to be running one subwoofer, it is rated at 200w
-what should i set the amplifier to? ST or BRG?
-what subwoofer level should i set it at? 80 or 120?
-would a different amplifier with more power solve my problem?
-the protection light comes on with the amp, i'm not sure what that means
thanks a lot to those who answer my questions, i tried to be as in depth as i could
Posted By: tex12gage
Date Posted: February 07, 2006 at 9:30 AM
i would start of testing the wires the previous owner left there. Check 'em all with a DMM.
Next, (if your amp is stable) bridge your sub wiring,   (sub + to amp left + /  then sub - to amp right -)
Set your amp to bridged.
Hope this works out, just check wires first.
TEX
