gauge remote turn-on?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=72631
Printed Date: May 15, 2026 at 6:48 PM
Topic: gauge remote turn-on?
Posted By: groggy23
Subject: gauge remote turn-on?
Date Posted: February 11, 2006 at 4:48 PM
What kind of wire can you use for remote turn-on lead?  does it matter if it the gauge is bigger/smaller?  I just ran out and I have some scrap 16 gauge speaker wire laying around...
Posted By: coppellstereo
Date Posted: February 11, 2006 at 5:28 PM
That should do the trick.  Just wiring one amp?
Posted By: groggy23
Date Posted: February 11, 2006 at 5:37 PM
^He has 2 amps one running 100W rms and the other 200W rms @ 14.4v  I'm planning on routing them in the middle as I did with the RCA's..
Posted By: kirktcashalini
Date Posted: February 11, 2006 at 6:59 PM
Might not want to run power wires right next to the RCAs.   heads up.
Posted By: groggy23
Date Posted: February 11, 2006 at 7:27 PM
^Thats what I thought crutchfield keeps on confusing me on where to run my remote wire. Because they have their's running by the RCA's on the passenger side. I'll just run the remote wire next to power...
Date Posted: February 11, 2006 at 7:31 PM
oooh my bad. remote would probably be fine. Not much current passes through that. I did RCA and the phone line (for boost) on one side. and Power, and remote on the other. I dont know 100% whats the best theoreticaly. If it works, it works.
Date Posted: February 11, 2006 at 11:14 PM
I ran the remote next to RCA on my last install, but I usually run it with the power as well.  It doesnt put out much power and I hope wont add much noise to the RCA's.  I'm not sure at what point it is best to use a relay with remote turn on connections.  The more amps you try to turn on with the one wire, could lead to problems with the HU overheating and maybe the remote circuit could get fried.
Lets see what other people think, how many amps can/should you run off of one remote turn on wire?  And will it add much noise if run by the RCA's?  How much power is typically going through the r.t.w.?
Posted By: Alpine Guy
Date Posted: February 11, 2006 at 11:32 PM
2 amps is usually the most you should power your remote with without a relay. You can run the remote wire with the rca's or with the power wires, heck, tests have proven you can run your rca's with your power wires and no extra noise is added to the rca's, its just a myth from back in the day.  If there is noise in your power wires, it going to be everywhere else in the car no matter where you put your rca's.
Date Posted: February 11, 2006 at 11:48 PM
The power wires dont emit EMI?  Or is there a threshold - up until a certain point the interference is inaudible?
Posted By: stevdart
Date Posted: February 12, 2006 at 5:29 AM
Buy a spool of 20 ga. Bell wire from the hardware store and you will have remote turn on wiring for a long time.  Cheap.
Posted By: j_darling2007
Date Posted: February 12, 2006 at 8:10 PM
The average HU is capable of about 600 miliamps.  The average amp draws about 250 miliamps.  So 2 amps should be the most ran off the HU without the use of a relay.
There are 3 kinds of people in the world, those who can count and those who can't
Posted By: groggy23
Date Posted: February 13, 2006 at 12:47 AM
^Thats very good information to know. The setup I have currently is CDA-9827 HU with Alpine T220 and MTX202 amps.. I'm guessing thats ok or within that miliamp range. I've read a bunch on bcae1.com but it didn't really talk about splitting remote turn-on leads to multiple amps. Do you know of a better information website about that stuff?
