amp having too much power for subs?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=72909
Printed Date: May 16, 2026 at 4:22 AM
Topic: amp having too much power for subs?
Posted By: anonymous user
Subject: amp having too much power for subs?
Date Posted: February 15, 2006 at 9:46 PM
i recently traded my PSP with many accories for some car audio, which conists of te following earthquake PHD2000W amp, (2)TremorXR-12 subs, and one of earthquakes amp wiring kits.i would like to know if a Earthquake PHD2000W amp would over power 2 Earthquake TremorXR-12's?
heres the specs thier site lists.
PHD2000W
Number of channels: 1 / Mono Block
Max power output:      2000 Watts
RMS power 2-ohm:        1000 Watts
RMS power 4-ohm stereo:      500 Watts
Damping factor:      >800
Cross over slopes:      24dB/OCT
THD:      >0.016
SNR:      104dB
Class:      "D" Digital
Speaker connection:      10-Gauge
Recommended
power connection:      4-Gauge
Input type:      Independent Low Level RCA
heres the specs on the subs....
      MODEL: TremorXR-12
    * 800 watts
    * Fs = 27Hz
    * Qms = 5.3508
    * Qes = 0.7217
    * Qts = 0.6359
    * VAS = 2.40Ft
    * Xmax = 0.5"
    * 87dB 1W/1M
    * Revc = 6.67
    * Levc = 5.9mH @ (1 kHz)
    * 2" Single Voice coil/8ohms
im planning to wire them up in a parallel to get a 4ohm load.
posted_image
Posted By: kfr01
Date Posted: February 15, 2006 at 11:38 PM
Amps don't break speakers or overpower speakers.  Idiots do.
Turn the gain down a bit and learn what clipping sounds like.  Don't clip the amplifier.  You'll be fine.
Read https://www.bcae1.com/ for more information.
New Project: 2003 Pathfinder
Posted By: stevdart
Date Posted: February 16, 2006 at 7:33 AM
Dude, you're stuck with the name "anonymous user" forever.  Not very personal, is it?  ;)
Posted By: jstruckman
Date Posted: February 16, 2006 at 10:19 AM
If it is a monoblock amp, why would there be a 4 ohm stereo rating? i am guessing that is a typ-o and they mean 4 ohm mono. Any way since you have two 8 ohm subs you will be running a 4 ohm load over all, which the amp claims 500 watts, that means 250 watts to each sub. The rating of the sub is 800 which is probably max rating, so more like around 400 watts RMS. In this case, You will not be overpowering the subs at these ratings.
Jazzy
