Ford factory radio non-mach + factory sub
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=73239
Printed Date: May 02, 2026 at 10:19 PM
Topic: Ford factory radio non-mach + factory sub
Posted By: lesserblue
Subject: Ford factory radio non-mach + factory sub
Date Posted: February 21, 2006 at 10:07 AM
Is there a way to add the OEM factory sub to a non mach radio? I have a 2002 Ford Escape and would like to add the factory sub. I know it's not the best but it should fit the need/void. I'm not looking for head pounding/throbbing bass just a little more low-end than what is there.
Question are:
1. Is there a way to hook up the factory sub to the non-mach radio (p/n 1c3f-18c815-ab)?
2. Is there a different radio (mach version) which has the same wiring harness as mine but with the sub out?
ps. Currently buying aftermarket is out of the question.
Posted By: ta400
Date Posted: March 01, 2006 at 6:54 PM
a thing is sour, it is that one you needs the amplifier of origin to make this modification for the remainder I can send the 3 to you graph which I have so that you voice the difference between what you have and what you wants to make.
p.s. sorry i'm a franch people :S  I espere that you include/understand me
ta400
Posted By: godblessdremil
Date Posted: March 01, 2006 at 9:58 PM
Can you give more information please, now i am assuming by non-mach you are refering to an aftermarket radio, how is the radio installed with a harness that plugs into the factory wires or an amplifier was used to drive door speakers. I am assuming that your car at one time had a factory amplifier am i correct?
Posted By: phattbazturd
Date Posted: March 07, 2006 at 10:59 PM
it is kinda complicated but i can tell you how
BigC
