wiring problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=7340
Printed Date: April 06, 2026 at 5:54 AM
Topic: wiring problem
Posted By: JTMann16
Subject: wiring problem
Date Posted: December 29, 2002 at 4:00 PM
Alright, i just got my Rockford Fosgate punch 700x, but i'm not sure how to give it the signal from my headunit or whatever. I have a 99 grand cherokee w/ the infinity gold premium sound. On my last car, i just used the speaker level inputs from the speakers on the rear deck of the car, but considering all of my jeeps speakers are in the doors, i'm not sure how i'm going to get the signal to the amp. I'd rather not have to go into the back of the radio and mess w/ all the RCA patch stuff, but if that's what i should do, i will. If anyone has a suggestion or the same problem, please help me. thanks a lot.
Each to his Own...
Posted By: Velocity Motors
Date Posted: December 30, 2002 at 9:13 AM
There should be an OEM amplifier under the rear passenger seat when you fold it up. You can get he speaker wires from this point.
Posted By: JTMann16
Date Posted: December 30, 2002 at 11:06 AM
man, i don't know why i didn't think of that.... thanks a lot
Each to his Own...
Posted By: JTMann16
Date Posted: December 30, 2002 at 5:27 PM
alright, i know where the factory amp is... but which wires should i tap into? there are like 20 different wires, thanks
Each to his Own...
Posted By: JTMann16
Date Posted: December 31, 2002 at 10:18 AM
anybody?
Each to his Own...
Posted By: FullForce
Date Posted: January 02, 2003 at 1:12 AM
like JEFF said, get the wires at the amp and make sure you tap the wires on the output side of the amp ... best of my knowledge speaker wire colors are as follows
             Driver                             Passenger
light GREEN/                  +                light blue/red          FRONT
lt.GREEN/ dark green   -              light blue/black
WHITE/ violet                 +              WHITE/ violet               REAR
tan/dark green           -                tan/dark green
i know i posted the wire colrs as the same for the rear but that is what my info has for being the color AT the speaker, so if you can find that same color AT the amp the just "pop" the speakers with a battery to test the wires
Posted By: JTMann16
Date Posted: January 03, 2003 at 10:41 AM
Alright,  I also found a website that had a diagram of the wires, so i'm pretty sure i know which ones to tap into, thanks for the help
Each to his Own...
Posted By: demeanor
Date Posted: January 03, 2003 at 5:04 PM
hey JT...does that amp have speaker level input...because if you're going to tap into any wires for the RCA patch cable adapters it should be done to the wires coming from the head unit, not after the amp.  other wise the signal would already be amplified going into the amp and sound distorted at higher volumes.  the feed from the head unit goes through a coil that lowers the voltage to the RCA's which are low level signals.
It's better to ask a "STUPID" question...than to know a "STUPID" answer. :-)
Posted By: JTMann16
Date Posted: January 03, 2003 at 10:47 PM
yeah, it has speaker level inputs. I already tapped into the wires, and i think it's going to work, i just need to get my amp wiring kit and subs in from ups... taking forever, but thanks for the help
Each to his Own...
