subs placement in a convertible?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=73692
Printed Date: May 08, 2026 at 8:50 PM
Topic: subs placement in a convertible?
Posted By: psyon
Subject: subs placement in a convertible?
Date Posted: February 28, 2006 at 9:25 PM
in a convertible, do you want the subs facing forward or rearward?  i realize that the sound dynamics are completely different, so i was just wondering.  i have two tens in my sedan right now facing rearward - i don't know if moving them to my small convertible (cabrio) would change that at all?
Loving Car Audio since 1992
Posted By: psyon
Date Posted: February 28, 2006 at 9:34 PM
oh yeah this is for a sealed box application, two 10's pushing 250 watts total
Posted By: stevdart
Date Posted: February 28, 2006 at 10:33 PM
If you can design the sub enclosure so that it fits either toward the back or toward the front, and also fits firing toward the side...and with a rear bottom angle that allows it to be tilted upward....
posted_image
posted_image
...then you've covered all bases and can experiment with placement after the subs are installed.
Posted By: psyon
Date Posted: March 01, 2006 at 12:08 AM
thanks, but what should i do if the subs are already in a box? i already have the system, just moving it from one car to another. the box is a traditional rectangle, with both subs on the same side. should i fire the subs forward or rearward?
is there a general rule-of-thumb for convertibles?
