What to look for when buying an EQ
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=73811
Printed Date: May 07, 2026 at 1:36 PM
Topic: What to look for when buying an EQ
Posted By: Walkercustoms
Subject: What to look for when buying an EQ
Date Posted: March 02, 2006 at 8:51 PM
Buying and EQ. I will be removing my X-Over because its not doing it for me. I want more control and I want it up front with me. I know I will need front, Rear and Sub in/outs. I want contol is the main thing. What should I look for and what models should I look at?
Wade
Posted By: dwarren
Date Posted: March 02, 2006 at 8:57 PM
Well, a x-over is entirely different than eq. They serve two different purposes.
You can add an eq along with your x-over, as the x-over is necessary.
But the real question is why the need for an eq in the first place?
Posted By: geauxtigers
Date Posted: March 02, 2006 at 9:02 PM
What do you guys have against EQ's? : )
Posted By: arrow12
Date Posted: March 02, 2006 at 9:05 PM
We don't have anything against EQ's.  A lot of the time it isn't necessary for most people though.
That's my opinion. Take it, leave it, or correct me.
Date Posted: March 02, 2006 at 9:06 PM
I have the MA X-Over and it is just a pain in the ass to work with. We installed a systme and the guy had an old eq and it was a lot easier to work with and dial in then my x-over. Plus it is a flush mount x-over and I would like a din mount so I can form it in the front along with the HU.
Posted By: dwarren
Date Posted: March 02, 2006 at 9:10 PM
cross overs should be set and left alone, and for that matter eq's as well. You tune your system once (hopefully using a RTA) and then leave it.
It sounds like their are other problems here, aside from what an eq will solve.
What do you feel an eq will solve?
Date Posted: March 02, 2006 at 9:20 PM
That I do understand and putting that way you are right I should not have to really adjust anything but my sub. I run SPLs and the system I quess is fine. I don't know it just seemed that I got alot more out of the system with the EQ then I did with my system with the X-Over. They system is fine I just want more crisper highs and I am just not getting that from the X-Over and was woundering if I will get that with say a 11-band EQ. I hear the changes when adjusting the X-Over but, heard a lot more change in fq with the EQ. I guess I should just get one and play around with it I understand I may be compareing apples to oranges but, I have never will sat down and messed with an EQ. I was at the local show over the weekend and several guys were just running EQs and when I ask questions none of them could really give me an answer why the were.
Wade
Posted By: dwarren
Date Posted: March 02, 2006 at 9:25 PM
I feel eq's are used to fine tune systems, they are the last thing to add. They will only do so much.
So if you have the money and time, go for it, but just don't expect too much, especially those in dash units as they are rather limited. Have a look at the Audio Control products, real eq's that are worth while.
Posted By: stevdart
Date Posted: March 02, 2006 at 9:34 PM
With a decent mix of equipment:  head unit, amplifiers and drivers...most systems will have the crossovers they need, and the fine adjustments can be done using the HU.  The problem with planning a system with the addition of an EQ is that there is a preconception that the EQ will take the sound up to another level.  So, there is an inherent reliance on the EQ to perform this "upgrade".  This preconceived notion that the EQ must perform a vital task may lead to a less-than-stellar setup of the equipment on hand.
But if the system components were chosen for all the right reasons:  how you want to listen to the music, compatiblilty with each other, features in and of themselves...the system should be able to be set up to a highly refined level.  It is only after the setup, after lengthy listening and sometimes sophisticated testing, that an EQ should be considered to correct flaws that can't be overcome with the installed gear.  The reason for the EQ should be that the automobile environment needs some correction, not that the gear that you installed needs help.  You can only find the need for environment correction after the system is installed and tuned to its highest ability, and the listening/testing is done.
If you are at the point where you have determined that an EQ could be of additional value, look at the parametric equalizers over the graphic variety for a greater control over the sound.  Once the EQ is set, it remains as long as the system hasn't been changed.  So, controls do not need to be near your driving position.  HERE'S one reference of many that can be found with a google search.
Posted By: dwarren
Date Posted: March 02, 2006 at 9:42 PM
Are you questioning me?                                                  posted_image
Posted By: DYohn
Date Posted: March 02, 2006 at 9:50 PM
Wade, as has been said, an EQ and a Xover do two entirely different things.  Your post indicates you are trying to adjust the sound with a Xover.  It ain't gonna happen.
A Xover simply divides and splits a signal based on the frequency and sends different bands to different outputs.  It is used to send the subwoofer frequencies to the sub, the mid frequencies to the mid and the high frequencies to the tweeter.  Once it is set, it is set.  The main use for a Xover is to protect higher-frequency speakers from trying to play too low frequencies (and thus damaging them.)
An Equalizer is simply a sophisticated tone control.  It does the same thing as the bass and treble controls in your head unit, only it has several bands of adjustment rather than just two or three.  An EQ is a very powerful tool and they are often misused by people who do not really understand them.  The main use for an EQ is to cut peaks and boost dips in the system frequency response, but it cannot compensate for inadequate speakers or poor installation.
ALL systems that use more than one speaker per channel use a crossover of some type.  Some systems can benefit from the proper use of EQ to compensate for system problems.  In properly designed systems, both tools are set-once and forgotten.
A crossover will not give you "crisper highs" as it has nothing to do with adjusting the signal.  An EQ might allow you to boost the highs, but it will add noise and can cause other issues.  The best bet for getting "crisper highs" is to change out your tweeters with "crisper" ones.  posted_image
Date Posted: March 03, 2006 at 7:33 AM
You all are bad asses. Well this is what I will do. We are swapping out the 12s for a singal 15 and the car is now all disassembeled and when I put it back together I will not add anything else to the system execpt for the 15 and I will grap my dads RTA (joys of a dad that runs concerts and crap like that) and really dail the system in and not add anything else and see if I can get to where I want it.
Wade
