Kenwood KAC-7201 Not Working?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=73996
Printed Date: May 06, 2026 at 3:00 AM
Topic: Kenwood KAC-7201 Not Working?
Posted By: bordominc
Subject: Kenwood KAC-7201 Not Working?
Date Posted: March 05, 2006 at 7:53 PM
I just bought a used kenwood kac-7201. I hooked everything up, the fan comes on, and a blue light flashes, however, no sound came out. After searching forums, I found that the blue light is a circuit protector. I'm not sure whats wrong with it...I know my rca cables are fine as I had another amp wired before this one. I took the amp a part and nothing appears to be burned. Anyone know what it could be?
Posted By: geepherder
Date Posted: March 06, 2006 at 6:50 AM
First check the speakers/wiring.  You may have too low an impedance (ohms) connected to the amp.  This could be caused by the speakers, or maybe a wire is shorting to ground.  If you can find a manual, it will say what the amp can safely handle.
