power problems
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=74304
Printed Date: April 02, 2026 at 4:18 PM
Topic: power problems
Posted By: chrislo09
Subject: power problems
Date Posted: March 11, 2006 at 6:14 PM
I am installing a new deck into my 03 malibu.  I am using a wiring harness, the gmrc-05, and I have no power.  I hooked up the deck and it will take and eject cd's, but it won't turn on.  I tried to re-hook up the ignition wire, but it still won't turn on.  Any help or idea's would be greatly appreciated.
Chris Rocks
Posted By: coppellstereo
Date Posted: March 11, 2006 at 7:18 PM
Look through the manual. There might be some sort of reset function. Did you hook up the illumination wire? sometimes that makes the displays really dim if not done right.
Date Posted: March 11, 2006 at 8:01 PM
I reset the deck and still nothing.  I also made sure the illumination wire was hooked up securely and correctly and still nothing.  I am stright up mind boggled.
Chris Rocks
Posted By: geepherder
Date Posted: March 11, 2006 at 9:18 PM
It's likely a power problem.  Ensure both your constant and switched leads are showing what they should.
Date Posted: March 11, 2006 at 10:57 PM
I hooked my ignition to my constant and the deck turned on.  How do I fix the problem with the ignition wire, xince that is what it must be.
Chris Rocks
Date Posted: March 12, 2006 at 6:15 AM
You've probably got a bad integration piece (gmrc-05).  The reason I say this is because it's supposed to supply the switched lead- if it didn't have constant power, it wouldn't be able to do this.
Date Posted: March 12, 2006 at 8:46 AM
How can I fix this integration piece?  or do I have to get a whole new harness?
Chris Rocks
Date Posted: March 12, 2006 at 6:53 PM
Whether you can fix it or not, I would return it for another.  If you came to my store with a problem, and there was evidence that it had been tampered with, I'd make you buy another.  Don't try to fix it.
